Loader 75 ford 4000 with 735 loader
   / 75 ford 4000 with 735 loader #1
roazo
Easton, Mo
Ford 4000
I having left front wheel bearing problem, have replaced left front bearings 4 times , the cotter key shears and nut backs off until bearings eat them selves up.Only happens on left front, I have replaced the spindle once. still having same problem, use mostly for mowing large yard, is the loader to heavy for the tractor?
   / 75 ford 4000 with 735 loader #2
did you replace the race with the bearing or only the bearing.
   / 75 ford 4000 with 735 loader #3
Is the spindle scored where the bearing sits and is there a keyed washer between the bearing and castle nut? Are you using a good quality cotter pin (not Harbor Freight) and is it the largest pin that will fit through the hole?
Yes , replaced both bearings & races
Yes to all above
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
WB Mower (A50120)
WB Mower (A50120)
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2017 Case IH Magnum 380 ROWTRAC CVT Tractor (A53342)
2017 Case IH...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
