Loader 75 ford 4000 with 735 loader
   / 75 ford 4000 with 735 loader #1
roazo
Easton, Mo
Ford 4000
I having left front wheel bearing problem, have replaced left front bearings 4 times , the cotter key shears and nut backs off until bearings eat them selves up.Only happens on left front, I have replaced the spindle once. still having same problem, use mostly for mowing large yard, is the loader to heavy for the tractor?
   / 75 ford 4000 with 735 loader #2
did you replace the race with the bearing or only the bearing.
   / 75 ford 4000 with 735 loader #3
Is the spindle scored where the bearing sits and is there a keyed washer between the bearing and castle nut? Are you using a good quality cotter pin (not Harbor Freight) and is it the largest pin that will fit through the hole?
Yes , replaced both bearings & races
Yes to all above
2005 Morgan Corporation Flatbed Body (A50854)
2005 Morgan...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
2005 OTTAWA T2 YARD SPOTTER (A51222)
2005 OTTAWA T2...
