75 Ford 400 FEL Speed
   / 75 Ford 400 FEL Speed #1
john15nlt
Bridgeport Texas
Ford 2000 1969 gas / Ford 4000 1973 Disel
I have a 75 Ford 4000 with an aftermarket FEL. There has been an adapter plate added between the controls of the rear remote and the transmission.
Here are my questions: the response on the FEL is very slow, it has plenty of power it just takes forever for it to get there. There is a what looks like an adjustment knob of the front of the hydraulic adapter but without knowing what it does I have not messed with it. I also understand there might be some restrictors in the lines to keep accidents from happening. Is there a way to upgrade the pump so I get better response, or is this fine.
Finally on the rear remote I get power up gravity down but how does the fluid get back witn only one line?
   / 75 Ford 400 FEL Speed #2
Hooking up to the tractor hyd's via an adaptor plate = slow, sorry. To increase speed/flow, the loader should have a front mounted pump, run by a driveshaft from the engine crank. That also means a reservoir and considerable plumbing. $$$$
So where do you find such a pump?
2016 Hitachi XZ300LC-6 (A47477)
2016 Hitachi...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
2013 UTILITY VS2DX DRY VAN TRAILER (A54607)
2013 UTILITY VS2DX...
2019 TAKEUCHI TL8 SKID STEER (A52705)
2019 TAKEUCHI TL8...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
2021 JOHN DEERE 624P WHEEL LOADER (A52705)
2021 JOHN DEERE...
