75 Ford 400 FEL Speed
   / 75 Ford 400 FEL Speed #1
john15nlt
Member
Bridgeport Texas
Ford 2000 1969 gas / Ford 4000 1973 Disel
I have a 75 Ford 4000 with an aftermarket FEL. There has been an adapter plate added between the controls of the rear remote and the transmission.
Here are my questions: the response on the FEL is very slow, it has plenty of power it just takes forever for it to get there. There is a what looks like an adjustment knob of the front of the hydraulic adapter but without knowing what it does I have not messed with it. I also understand there might be some restrictors in the lines to keep accidents from happening. Is there a way to upgrade the pump so I get better response, or is this fine.
Finally on the rear remote I get power up gravity down but how does the fluid get back witn only one line?
   / 75 Ford 400 FEL Speed #2
Hooking up to the tractor hyd's via an adaptor plate = slow, sorry. To increase speed/flow, the loader should have a front mounted pump, run by a driveshaft from the engine crank. That also means a reservoir and considerable plumbing. $$$$
So where do you find such a pump?
2016Takeuchi TL8 (A47477)
2016Takeuchi TL8...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A53421)
2023 Caterpillar...
KUBOTA B7500 TRACTOR (A54756)
KUBOTA B7500...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A55787)
2025 GIYI GY-PG72C...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
