75 Ford 400 FEL Speed
   / 75 Ford 400 FEL Speed #1
john15nlt
Bridgeport Texas
Ford 2000 1969 gas / Ford 4000 1973 Disel
I have a 75 Ford 4000 with an aftermarket FEL. There has been an adapter plate added between the controls of the rear remote and the transmission.
Here are my questions: the response on the FEL is very slow, it has plenty of power it just takes forever for it to get there. There is a what looks like an adjustment knob of the front of the hydraulic adapter but without knowing what it does I have not messed with it. I also understand there might be some restrictors in the lines to keep accidents from happening. Is there a way to upgrade the pump so I get better response, or is this fine.
Finally on the rear remote I get power up gravity down but how does the fluid get back witn only one line?
   / 75 Ford 400 FEL Speed #2
Hooking up to the tractor hyd's via an adaptor plate = slow, sorry. To increase speed/flow, the loader should have a front mounted pump, run by a driveshaft from the engine crank. That also means a reservoir and considerable plumbing. $$$$
So where do you find such a pump?
1996 Elgin Pelican Series S Street Sweeper (A55787)
1996 Elgin Pelican...
2012 Infiniti G25 Sedan (A55758)
2012 Infiniti G25...
2015 CAT D5K2 LGP (A47477)
2015 CAT D5K2 LGP...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
Portable Restroom (A54865)
Portable Restroom...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A55788)
2017 Freightliner...
