7400
   / 7400 #1
curtisdg
tractor won't back up in range B
   / 7400 #2
If the engine sounds like it's under load you have clutch problems. Expensive. Check the oil and smell if burnt. If not shift fork has been jammed or bent, pretty easy fix.
   / 7400 #4
That shouldn't even be possible!!!
   / 7400 #6
What I meant was this. Ordinarily, the range transmission is behind the gear transmission. Forward/reverse functions are taken care of in a reverser or by a countershaft in the gear tranny. Sounds more like an issue in the differential.
   / 7400 #7
He could be shifting A-B pretty hard without barely using the clutch.
   / 7400 #8
True. I had not allowed for idiotic operator behavior.
Miscellaneous electrical stands (A53117)
Miscellaneous...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
Baker BFD80 8,000lbs Diesel Forklift (A51691)
Baker BFD80...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
