7400
If the engine sounds like it's under load you have clutch problems. Expensive. Check the oil and smell if burnt. If not shift fork has been jammed or bent, pretty easy fix.
What I meant was this. Ordinarily, the range transmission is behind the gear transmission. Forward/reverse functions are taken care of in a reverser or by a countershaft in the gear tranny. Sounds more like an issue in the differential.
He could be shifting A-B pretty hard without barely using the clutch.
True. I had not allowed for idiotic operator behavior.
KILLBROS GRAVITY FLOW WAGON (A64277)
KILLBROS GRAVITY...
2019 AUTOCAR XPEDITOR TRASH COMPACTOR TRUCK (A63276)
2019 AUTOCAR...
2022 Kaufman Trailers Trailer, VIN # 5VGFW5035NL009932 (A65563)
2022 Kaufman...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
John Deere 2 Row Planter (A65640)
John Deere 2 Row...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
Here are some similar links:
