7400
If the engine sounds like it's under load you have clutch problems. Expensive. Check the oil and smell if burnt. If not shift fork has been jammed or bent, pretty easy fix.
What I meant was this. Ordinarily, the range transmission is behind the gear transmission. Forward/reverse functions are taken care of in a reverser or by a countershaft in the gear tranny. Sounds more like an issue in the differential.
He could be shifting A-B pretty hard without barely using the clutch.
True. I had not allowed for idiotic operator behavior.
2022 EZ-GO ELITE...
Stout Rock Bucket Grapple HD72-3 (A66285)
Stout Rock Bucket...
Zenith Pallet Jack Truck (A66408)
Zenith Pallet Jack...
72in. Fork Extension (A64553)
72in. Fork...
2021 NEW HOLLAND 185 MANURE SPREADER (A64277)
2021 NEW HOLLAND...
2005 CATERPILLAR 416D BACKHOE (A65053)
2005 CATERPILLAR...
