7400
If the engine sounds like it's under load you have clutch problems. Expensive. Check the oil and smell if burnt. If not shift fork has been jammed or bent, pretty easy fix.
What I meant was this. Ordinarily, the range transmission is behind the gear transmission. Forward/reverse functions are taken care of in a reverser or by a countershaft in the gear tranny. Sounds more like an issue in the differential.
He could be shifting A-B pretty hard without barely using the clutch.
True. I had not allowed for idiotic operator behavior.
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
2007 Jeep Commander (A62613)
2007 Jeep...
2025 ALCOM XPRESS XLT 24FT T/A CARGO TRAILER (A59914)
2025 ALCOM XPRESS...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
Here are some similar links:
