7320 Shuttle Shift Problem and Possible Fix
/ 7320 Shuttle Shift Problem and Possible Fix #1
MickeyDBC
Dime Box,Tx
Kioti RX7320PC & NX4510HST
I have a 3 year old 7320 that started having some strange transmission/clutch problems a couple of months ago. The main symptom, was the clutch pedal stopped working but at other times the forward/reverse lever also quit working. Turning off and restarting the tractor would fix it, at least temporarily. Weekend before last it started acting like I was randomly pushing in the clutch pedal, so not good. Stopped by the dealer and they said that had seen a couple of failures of the transmission control module (about $700 to replace). The module is under the cab floorboard and has a pair of large multi-pin connectors. Before spending that much money I decided to clean the connectors with CRC electronics cleaner. Took about an hour and a 10mm deep socket and it seems to have fixed it. I am going to order some cleaner/preservative and O-ring grease for the next time it happens, but for now it seems to be fixed.
/ 7320 Shuttle Shift Problem and Possible Fix #2
I hope that fixes it permanently.... sounds like it will. Good idea about the grease!
OK TRAILER  16 FOOT TRASH TRAILER (A68842)
OK TRAILER 16...
1997 LEDWELL 48FT DOVETAIL TRAILER (A67714)
1997 LEDWELL 48FT...
1998 CHEVROLET C7500 (INOPERABLE) (A67714)
1998 CHEVROLET...
2015 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2015 (INOPERABLE)...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A67714)
2008 FOREST RIVER...
