7320 Shuttle Shift Problem and Possible Fix
/ 7320 Shuttle Shift Problem and Possible Fix #1
MickeyDBC
Gold Member
Dime Box,Tx
Kioti RX7320PC & NX4510HST
I have a 3 year old 7320 that started having some strange transmission/clutch problems a couple of months ago. The main symptom, was the clutch pedal stopped working but at other times the forward/reverse lever also quit working. Turning off and restarting the tractor would fix it, at least temporarily. Weekend before last it started acting like I was randomly pushing in the clutch pedal, so not good. Stopped by the dealer and they said that had seen a couple of failures of the transmission control module (about $700 to replace). The module is under the cab floorboard and has a pair of large multi-pin connectors. Before spending that much money I decided to clean the connectors with CRC electronics cleaner. Took about an hour and a 10mm deep socket and it seems to have fixed it. I am going to order some cleaner/preservative and O-ring grease for the next time it happens, but for now it seems to be fixed.
/ 7320 Shuttle Shift Problem and Possible Fix #2
I hope that fixes it permanently.... sounds like it will. Good idea about the grease!
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
24" Mini Excavator Bucket (A66285)
24" Mini Excavator...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
