7205 Electrical Issue?
/ 7205 Electrical Issue? #1
Licklog
East Tennessee, GSMNP, Sevierville, Pigeon Forge,
CC 7205
I was working outside today and turned the tractor off while I was loading the carryall with split rail fencing. When I went to start it back up, I turned the key, it energized and then it quit. No power at all to the panel, lights, etc., except that I could hear a slight buzz when I moved the turn signals.
I checked battery, fuses, line fuses, etc. No joy, still as dead as a doornail. Any thoughts or ideas on where to go from here would be much appreciated.
Licklog
/ 7205 Electrical Issue? #2
Try jump starting it. If that works, replace your battery.
Thanks for your reply.
Here's what I found just a few minutes ago. I had cleaned and tightened the battery terminals after checking the fuses. Then put the battery charger on. After your postings I went out to check the charger and found that it was "charged" . Then for the heck of it I turned the key. Same result, energize then dead. That sent me back to the battery and the cables.
I found that even though I had tightened the bolts on both cables the bolt on the positive terminal had broken in half and was just tightening to one side of the terminal. Put a clamp on to test and voila off she went. Success....
Thanks for your help.
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
1143 (A63745)
1143 (A63745)
Bobcat Mini Grapple (A64126)
Bobcat Mini...
2006 Hudson Brothers Trailer HTD18D Trailer (A62613)
2006 Hudson...
2011 FORD F-150 (A65643)
2011 FORD F-150...
CASE 588H ROUGH TERRAIN FORKLIFT (A64276)
CASE 588H ROUGH...
