7194 diesen injector pump reassembly ?
/ 7194 diesen injector pump reassembly ? #1
SDmod
Cub cadet 7194
I've never been afraid to tackle tough problems, but may have bitten off more that I should.
My injector pump no longer delivered fuel to the top injector ports, so I pulled the pump and took it apart.
I noticed that the rack and pinion fuel shut off mechanism was jammed by a broken tooth from one of the 3 pinion gears.
I removed the damaged tooth(and am waiting for the new part to arrive) but am wondering about reassembly.
The orientation of the pinion relative to the fuel shut off rack will obviously affect the function of the pump to shut off/or allow fuel to flow.
I can't find anything in my service manual on this level of detail, so hoping someone here has the knowledge they would be willing to share.
/ 7194 diesen injector pump reassembly ? #2
maybe thepumpguysc will chime in. He rebuilds injector pumps
/ 7194 diesen injector pump reassembly ? #3
The gear has a dot on it or a cut tooth.. that lines up w/ the line on the control rack..
The pumping plunger goes in w/ the cut on the end {helix} AWAY from the control rack.
good luck..
Thank you for the help !!
