7018 vs 6013 vs everything else
   / 7018 vs 6013 vs everything else #51
I see some of pipefitter/ flange jockeys work! He is amazingly consistent, I'm always in awe of he work.
This is my experience and I confess it is not as versed as others. The engineer will spec the procedure and I have to weld within that spec. Personally I love 7018, but I like 5p too. 6013 is great to learn with and is way cheaper to learn to control that "style" arc for ss than stainless rods. Yep I worked for some very cheap folks. I did a job several years ago that speced 70xx. I used 7018 Excalibur because I had them, if I would have had 7014 guess that tower brace would have been stuck with it. Pipeline hot taps spec 7016 on roots a lot and 7018 cap.
My opinion is learn to weld with them all. Make good welds with them all. General repairs on mild steel any of them are good is used properly. 7018 will take some abuse no doubt. But better rods can only do do much for poor planning, prep, and execution. Surely I can get a Amen!
   / 7018 vs 6013 vs everything else #52
Where do you get 7016? It is an earlier low hydrogen electrode before 7018 for the most part but basically the same. A lot of stainless is XXX(L)16 though. In Alberta 6010 is used for most root passes in the field unless it's real critical, then TIG is used. It is good to learn to use all the different rods. You never what you're going to run into. Once you get the hang of 7018, you'll like it more than most other rods. It just needs more practice.
   / 7018 vs 6013 vs everything else #53
.... Once you get the hang of 7018, you'll like it more than most other rods. It just needs more practice....
Practice? Pratice? Are we talking about Practice? (semi-famous Allen Inverson interview/rant from a few years ago which sports fans will likely remember).
That is just it. Most of us backyard types do not spend the time practicing like we should (me included). This is yet another reason some of the various rod types do exist. You can grab the rod type that has the best characteristics for the job at hand, will also run well on your welding power source, easy to use with users minimal skill set, and with minimal practice get the job done.
Likely, it will not be to a professional welders code book of using 6010 and 7018. That said, all my ole junk in use around this place has zero 6010 or 7018 welds in it and it is all been repaired just fine without a single weld failure that I have added. (That said, I do not weld on anything that goes up and down the public roads as I do not trust my skill set as worthy of that degree of trust. I am not willing to put in the practice or the formal training to make sure my welds would be roadworthy either. Simply no time in my life for that luxury).
   / 7018 vs 6013 vs everything else #54
7016 is readily available in Australia and as far as I know it is used a great deal more than 7018. As stated before 7016 & 7018 are basically the same although to the best of my knowledge
7018s contain more iron powder.
Have only used 7018s once and found them good to use, having a 300amp DC welder probably helped.
When using the engine driven welder (225amp DC) , I have been using 7016s most of the time and as said it just needs practice.
   / 7018 vs 6013 vs everything else #55
I think the only time I ever used 7016 was in 1974. I remember the welds looked like they had a lot of chrome in them, somewhat like stainless steel. I remember the job was all overhead welding, had to stand on the hand rail, and weld with both hands and reach out about as far as you dared,:eek: to get the job done. To me the 7016 ran just like 7018, just looked a little different is all.
   / 7018 vs 6013 vs everything else #56
Shield Arc said:
The welding inspectors would not allow the guy in the rigging gang to tack with anything but 7018. And the 7018 had to be kept in an oven. We had to have 3-ovens on site, and keep a log book for each oven on how many pounds of rod was removed from which oven, how many pounds were put back in the which oven at night, along with times. All just to tack, the welding crew were all using wire feeders
That's a good example of "A _little_ knowledge is a dangerous thing"
   / 7018 vs 6013 vs everything else #57
I bought an ac 225 Lincoln last year from a company I worked for. It's was new they just did not use it. I have enjoyed welding stuff with 6011 and 6013. It's kinda fun, your stuck on tapped settings and you make do. It makes you prep things better, it'd not as easy to walk over stuff. I have fixed trailers , built ramps, repaired all kinda stuff with it. It make the nice welders even nicer!
   / 7018 vs 6013 vs everything else #58
There's not a thing wrong with a good ol' AC buzzbox welder. I enjoy using mine. And you're right, it is fun. :cool:
A lot of farmers used them when I was growing up in the 50's & 60's. And the welding class in high school used an old ac buzzbox that had a carbon arc torch with it. We kids learned to weld and braze using it. A friend and I used it to weld and braze 2 old car hoods together to make a boat, as a class project. That was a lot of fun and we learned a lot doing it.
When I retired a few years ago, I bought a Miller Thunderbolt 225AC and have enjoyed it a lot. I have made projects with it and have done a lot of repairs on farm equipment. I have mistreated it from time to time getting jostled around in the back of my pickup and being accidently left outside, but have never worried about it breaking down on me. It's as reliable as the day is long. :thumbsup:
The only thing I hate is not being able to buy a carbon arc torch for it. They aren't being made anymore. Guess I'll have to make one or find someone that's willing to part with theirs.
   / 7018 vs 6013 vs everything else #59
Yep Good ole AC Buzzbox is needed for a Twin Carbon Arc Torch. I now have 3 Twin Carbon Arc torches ( 1 Wards and 2 Lincolns). Closest thing to a free lunch that exists in this world. I use mine to heat stuff for bending and free rusted nuts. Have yet to use it to silver solder, braze, or flame fill weld. Only consumables are electricity which is cheap compared to Acetylene.
Frankly, I can not tell a world of difference welding on DC to AC at high amp settings. I can usually make either do what I need. That said, I can tell the biggest difference between AC and DC on the lower than 50 amp settings, then I much prefer DC.
   / 7018 vs 6013 vs everything else #60
The only thing I hate is not being able to buy a carbon arc torch for it. .[/QUOTE]
Can you get the correct carbon rods.
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A51039)
2007 Freightliner...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
3in Poly Pipe (A49461)
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
LIGHT BAR AND WIRING (A50854)
LIGHT BAR AND...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
