7014 rod
/ 7014 rod #21
Furu, I have the 200ST as well and it runs WAY hot as well. 1/8 rod I run between 60 and 80 amps depending on the steel. You have that 300, right?
That seem really strange. Hopefully Mark can shed some light on what is going on there.
/ 7014 rod #22
Gary Fowler - you are the first I've seen bring up an issue with mild steel and hydrogen cracking. I researched it further to locate a reference.
Here is the only one I've found so far, but it is interesting. http://products.asminternational.org/fach/content/fach9001/fach90011/fach9001113.html
(I expected to not find any, but since I did find one I included it)
The rod used in this case was 7024, they specifically mentioned using 7018 as a solution.
Hydrogen-Induced Cracking of Welded Truss Gusset Plates
William F. Jones III, Consulting Metallurgical Services, Inc.
From: Handbook of Case Histories in Failure Analysis, Vol 1, K.A. Esakul, Ed., ASM International, 1992
Abstract: Six cracked A36 steel gusset plates
/ 7014 rod #23
For probably 98%+ of the projects welded on here, hydrogen cracking won't be a concern and 7018 only needs to be in an oven when doing critical code welding. It has to be kept dry and away from moisture but you don't need to go out and buy a rod oven. It does burn nicer out of an oven though. As far as burning it colder and going slower to get better fusion, that's a contradictory statement. Burn it where it flows properly.
/ 7014 rod #24
LH rods or any rod with a coating that contributes to the weld metal pool needs to be stored dry and preferably heated to above 250F.
I would respectfully disagree with part of this statement. All rods need not be stored in an oven. 6010, 6011 are specifically not to be stored in an oven.
Storage temp for several rods is well under 250F.
Clearly you are correct that LH rods should be stored in an oven - but I contend for normal home use it's not critical.
Here is a couple sample tables on the topic of temperature (for those that have not seen them).
/ 7014 rod #25
Well, this is interesting.
Everyone knows, or at least should know, that LH rod like 7018 need to be heated in an oven to be code compliant.
But, I had no idea that non-LH rod with a coating that adds to the weld metal, could cause hydrogen embrittlement. And the fact that they would need to be kept dry, preferably heated to above 250F for an hour, is very seldom complied with.
For some non-LH rod to cause hydrogen embrittlement to the point of failure, must be pretty rare.
I can understand it more with 7014 & 7024. But that 6013 might need conditioning, is really a shocker. I'll bet there's been many an old farmer that have repaired their implements with their old buzzboxes and damp 6013's. :)
/ 7014 rod #26
That's not what Gary said, he said low hydrogen or any electrode where the coating is incorporated into the weld metal (like 7024, 8024 etc). Gary's post would exempt 6010 and 6011 from going in the oven
/ 7014 rod #27
Re: old farmer using damp 6013 with buzz box. That would have been me.
/ 7014 rod #30
Since the thread has gone "dry" -
I've bought some of the HF rod storage tubes.
Would it be worth adding a dessicant keep the rods dry? I'm down in Mississippi, my shop doesn't have a/c and it's 94 deg F w/ 50% hmidity.
/edit - and what the heck do they use for rods in that picture? A 5lb box of 1/8 FILLS the tube. Those must be 1/32 rods.
/ 7014 rod #31
Sorry, I didn't mean to call you old. :laughing:
My 13 year old daughter has a 63 year old dad. I hear it every day.......:)
Terry
/ 7014 rod #32
I think pretty much every stick electrode has something in the coating/flux that goes into the weld metal. All rods can pick up hydrogen. I think I read 6010 is actually more prone to picking up hydrogen. 7018 and other XX18 are called low hydrogen because they pick up the least amount of hydrogen. For critical work they are kept in an oven to keep the lowest possible hydrogen pick up properties. I doubt anyone on here really needs to worry about hydrogen embrittlement.
/ 7014 rod #33
A small point, but the flux picks up moisture, the hydrogen disassociates in the arc to introduce hydrogen to the weld.
I'm not strong in chemistry in any way, that's just how the technical papers I've read explain the process.
I also completely agree that for most people, this is a moot point and won't bother anything welded at home.
/ 7014 rod #34
Terry
I understand, Terry. Mine do the same to me.
Payback, though is calling them your "Baby" in public. :cool: :D
/ 7014 rod #35
I understand, Terry. Mine do the same to me. Payback, though is calling them your "Baby" in public. :cool: :D
I was showing her a pic of GE welder from the 1930' s yesterday. Her response? Quote: I know of an older looking weldor from the early 1950's :(
Terry
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
Generac Generator (A61572)
Generac Generator...
2009 Ford F-450 Liftmoore 5000 2 Ton Crane Service Truck (A61573)
2009 Ford F-450...
2022 JOHN DEERE 26G EXCAVATOR (A64279)
2022 JOHN DEERE...
2008 Ford Expedition SUV (A61574)
2008 Ford...
2022 EZ-GO ELITE...
