7010 Transmission cables
/ 7010 Transmission cables #1
Keltic
Cape Breton Island
13 LS 7010C,91 Kubota L4150,Thomas 153S< Can Car C-4,BobCat 35E, BobCat 590,Pete 378 Tandem, Lots of other junk.
Anyone had any issues? Had to adjust? Experiences?
/ 7010 Transmission cables #2
2012 LS 7010 with just over 600 hrs, I haven't had any issues.
/ 7010 Transmission cables #3
If you mean cables that run from shifter , then yes they are a problem.Mine were replaced with updated ones under warranty.Old one stretched.From what ive found,the problem is likely in the lower shifter controll mount.Take the plastic cover off and see if lowest bracket is moving.It is held in place by 2 phillips screws and they can get loose making it hard to get into gear.The holes are slotted so i tightened them up and put a bolt in a new drilled hole to fix the issue permanently.
Thanks a lot, mine seem stretched for sure, I'll check we my dealer for an update.
/ 7010 Transmission cables #5
Is this the synchro shuttle or the power shuttle or both? I see a person who owns a 7040 posted which I thought was a power shuttle only. I have a power shuttle and mine has been problem free.
It's not the power shuttle, I just spoke with the dealer and he gave me some hints for adjustment. He did say there is an updated cable to replace some cables that have the outer casing separate, but my problem is just adjustment issue hopefully. An other issue is the bracket at the base of the shifter breaking, I had this happen last week and welded it.
Need a new "updated" cable, one of mine was broken, 184.99 plus shipping, not really impressed at 550hrs.
/ 7010 Transmission cables #8
Did you happen to take a photo, I will have to check mine further. Expensive, just for a cable.
I'll take a picture of the two together, when I receive the new ones, I bought two in case the other one fails. Really kills me spending 500+$ on something I'm making payments on!
Updated vs original
/ 7010 Transmission cables #11
Thanks for posting pictures of the cables. Hopefully, the new ones will last for years.
Muck-Truck Wheelbarrow (A61567)
Muck-Truck...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
John Deere CP690 (A64126)
John Deere CP690...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
Bomag Roller (A63689)
