7000 Planter
/ 7000 Planter #1
swat1018
Frankton, IN
JD5400 / JD770 / AC 160
I am wanting to purchase a JD 7000 planter. I would like to have a 6 row, with no-till coulters. Is there a "rule of thumb" on how much HP is required to pull a planter, by the row, etc. I have a JD 5400 w/ front assist, will be used on level ground. Not sand, but far from hard clay. Any ideas?
/ 7000 Planter #2
There may be a "rule of thumb," but ag. engineers have developed formulas that allow you to make a more precise calculation. Google "Matching Tractor Horsepower and Farm Implement Size" to obtain a pdf file from Michigan State that is relatively simple to work through.
Steve
Edit. Based on the MSU report, you will be OK assuming your tractor hasn't lost a significant amount of HP over time.
/ 7000 Planter #3
With front assist and your tractor being 70 hp you should have power to pull around a 6 row 7000 planter.
As long as your tractor has rear remotes to lift and lower it you should be good to go. I know a lot guys are on my hunting forum are pulling 4 rows with 50 hp tractors. At 70 hp tractor will be close but judging on your soil conditions it should be a to handle it.
225/70R16 Tires - Set of 4 (A68134)
225/70R16 Tires -...
213087 (A64276)
213087 (A64276)
213121 (A64276)
213121 (A64276)
2025 60in Hydraulic Forks and Frame Skid Steer Attachment (A66734)
2025 60in...
1998 TRAIL KING TK70HT HYDRAULIC TAIL TRAILER (A67714)
1998 TRAIL KING...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
