$700 muffler?!? :o
/ $700 muffler?!? :o #1
macindude
Hubertus, WI
Simplicity Legacy
Hi all,
I'm in the process of doing some repairs to my Simplicity Legacy (see Simplicity Legacy w/25hp Kohler Command running really rich). I have the muffler off it for the first time since I've had it, and, well, there's an awful lot of loose metal in there. :ROFLMAO: I went to see what a replacement would run (P/N 1719787SM) and it's $700!!!
Does anyone know of a source for a muffler/exhaust in reasonably good condition for the Kohler CH25S on the Legacy?
/ $700 muffler?!? :o #2
Looks like that one is special. There are some less expensive ones on amazon that fit the ch25 series with different outlet locations. Maybe have to fab some pieces to get it right?
/ $700 muffler?!? :o #4
At least when I was a younger, there was always at least one guy who was real good at custom exhaust fab at the local Meineke. I had them moonlight a few hotrod jobs for me, after hours when they weren't dealing with their usual work. If I had a custom job like this, I'd be asking at the local offroad/speed shop if there's any such local guy, in your area. I'd bet you get the new muffler assembly made for under $300.
/ $700 muffler?!? :o #5
Hi all,
Check out this thread. This guy has a lot of Simplicity parts that he needs to sell -- you can read it for yourself. Maybe he can help you out.
Looking for Opinions on NOS​
/ $700 muffler?!? :o #6
Hi all,
I'm in the process of doing some repairs to my Simplicity Legacy (see Simplicity Legacy w/25hp Kohler Command running really rich). I have the muffler off it for the first time since I've had it, and, well, there's an awful lot of loose metal in there. I went to see what a replacement would run (P/N 1719787SM) and it's $700!!!
There was a guy on here very recently, trying to unload a garage full of NIB Simplicity parts, from an estate.
/ $700 muffler?!? :o #7
Here is the post. I would PM him if I where you
/ $700 muffler?!? :o #8
Guess I should have read first, and I would have seen someone already linked to that thread :)
/ $700 muffler?!? :o #9
I went to replace the muffler on my Ford 1100 back in the early 90's and it was over $500 back then. I went to a tractor boneyard looking for a different part and found a 1210 with a muffler on it that looked "pretty close"! I ended up having to make an adapter to mount it to the engine because it was a slightly larger version of the correct one.
To the O/P... straight pipe it!!!
David from jax
/ $700 muffler?!? :o #12
MacinDude have you checked out the Farm Fleet stores there in
Wisconsin? The one in Fond du Lac Farm Fleet has a very large
selection of exhaust parts many years ago maybe they still do???
willy
/ $700 muffler?!? :o #13
I once needed a muffler for a Craftsman lawn tractor back in early 2000's and they wanted $400 for it back then.
So my small engine mechanic made a new metal box, welded the head pipes to it, filled it with steel wool and it worked great and was quiet.
/ $700 muffler?!? :o #17
If there is just a hole in it find some asbestis to cover the
hole and put a tin can or some metal over to hold it in place
and hold this in place with some large hose clamps
willy
/ $700 muffler?!? :o #18
I love my elderly Yanmar tractors. Replica muffler assemblies are available and are under $100.
But today at 40 years old neither needs its muffler replaced.
I thought I read that the muffler assembly is needed on a small engine or otherwise the valves can be damaged by heat?
Is the muffler assembly like this? Amazon.com
Yes, it's very similar to that. That'd probably fit the engine, but it'd melt my hood. LOL
The original Simplicity part has an exhaust pipe that comes from the side of the muffler, not the end, and extends down to just below the front bumper, exhausting forward.
Now, since I'm not exactly going to be entering this thing in any tractor shows I could probably just take a hole saw and punch a hole in the side of the hood where this one exhausts, if I can't find the original part.
Sadly, I do not have the skills to fab my own just yet. I have already gained too many new skills in the course of this project! :ROFLMAO:
2018 KUBOTA  RTV-X1140 (A63569)
2018 KUBOTA...
2018 MACK PINNACLE (A63569)
2018 MACK PINNACLE...
2015 MACK PINNACLE (A63569)
2015 MACK PINNACLE...
Holly 12 Row Harrow (A64047)
Holly 12 Row...
1761 (A58375)
1761 (A58375)
2004 CATERPILLAR 242 SKID STEER (A64279)
2004 CATERPILLAR...
