Mowing 6t. finishing mower
/ 6t. finishing mower #1
intimidator
I have a ym 2210 and I would like to run a 6 ft. finishing mower. Has anyone had any luck running a 6 ft. mower with a 2210 or should I buy a 5 ft.
Thanks
Doug
/ 6t. finishing mower #2
I have a 2310 and it has no problem with the 6' finish mower. We have similar horsepower and weight in our tractors so you shouldn't have any problems. I do have small hills that I cut, and this does not affect the cutting. I also pull a 5' rotary brush mower and have had no problem cutting up to 2" brush. (I haven't had larger brush to run over yet)
/ 6t. finishing mower #3
I have a Ym1900 and run a 5ft mower. It could easily handle a 6 foot so you should not have any problems.
/ 6t. finishing mower #4
I use a 5' with my YM1700. No problem except when lifting it up with the 3pt. I get a little light up front.
/ 6t. finishing mower #5
I have the 2210 also and run a 6ft sitrex finishing mower with no problem, love that shuttle shift! get the 6ft with no worrys. later, erick
Thanks for all your input, Looks like I will be purchasing a 6 footer.
Doug
/ 6t. finishing mower #7
I have both a YM1700 and an F22D. I've run a 6ft Landpride finish mower behind both with no problems. The YM1700 will bog down in heavy grass, however, down shifting to a lower gear in that area solves that problem
/ 6t. finishing mower #8
I have a FF205D, and was told that the 6' finish mower was a bit too large. 205 weights 1950 lbs, 20 hp PTO. How much does the YM 1700 weigh?
/ 6t. finishing mower #9
Birdman...
I was just curious...
Did they issue that "8399" number at Alcatraz... /w3tcompact/icons/tongue.gif /w3tcompact/icons/wink.gif
/ 6t. finishing mower #10
Yeah they gave that number when I checked in. It took years to escape with the help of "lil Red" and the 30 inch scoop pan!
Actually it's the little bosses birthday!!
/ 6t. finishing mower #11
I have a YM 2010 and use a 6' mower and have had no problems - it works just fine in my 5 acres of bahia grass!
/ 6t. finishing mower #12
I loved that movie... watch very little today... /w3tcompact/icons/smile.gif
BUSH HOG 1815 - 15' BATWING ROTARY MOWER (A64277)
BUSH HOG 1815 -...
2013 FORD F-250 SUPER DUTY (A65643)
2013 FORD F-250...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2021 Gatormade Lowboy Trailer (A62613)
2021 Gatormade...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
2016 FORD E450 SHUTTLE BUS (A59914)
2016 FORD E450...
