Mowing 6t. finishing mower
/ 6t. finishing mower #1
intimidator
I have a ym 2210 and I would like to run a 6 ft. finishing mower. Has anyone had any luck running a 6 ft. mower with a 2210 or should I buy a 5 ft.
Thanks
Doug
/ 6t. finishing mower #2
I have a 2310 and it has no problem with the 6' finish mower. We have similar horsepower and weight in our tractors so you shouldn't have any problems. I do have small hills that I cut, and this does not affect the cutting. I also pull a 5' rotary brush mower and have had no problem cutting up to 2" brush. (I haven't had larger brush to run over yet)
/ 6t. finishing mower #3
I have a Ym1900 and run a 5ft mower. It could easily handle a 6 foot so you should not have any problems.
/ 6t. finishing mower #4
I use a 5' with my YM1700. No problem except when lifting it up with the 3pt. I get a little light up front.
/ 6t. finishing mower #5
I have the 2210 also and run a 6ft sitrex finishing mower with no problem, love that shuttle shift! get the 6ft with no worrys. later, erick
Thanks for all your input, Looks like I will be purchasing a 6 footer.
Doug
/ 6t. finishing mower #7
I have both a YM1700 and an F22D. I've run a 6ft Landpride finish mower behind both with no problems. The YM1700 will bog down in heavy grass, however, down shifting to a lower gear in that area solves that problem
/ 6t. finishing mower #8
I have a FF205D, and was told that the 6' finish mower was a bit too large. 205 weights 1950 lbs, 20 hp PTO. How much does the YM 1700 weigh?
/ 6t. finishing mower #9
Birdman...
I was just curious...
Did they issue that "8399" number at Alcatraz... /w3tcompact/icons/tongue.gif /w3tcompact/icons/wink.gif
/ 6t. finishing mower #10
Yeah they gave that number when I checked in. It took years to escape with the help of "lil Red" and the 30 inch scoop pan!
Actually it's the little bosses birthday!!
/ 6t. finishing mower #11
I have a YM 2010 and use a 6' mower and have had no problems - it works just fine in my 5 acres of bahia grass!
/ 6t. finishing mower #12
I loved that movie... watch very little today... /w3tcompact/icons/smile.gif
Land honor Mini Skid Steer (A60352)
Land honor Mini...
JOHN DEERE 323E SKID STEER (A64279)
JOHN DEERE 323E...
208315 (A58376)
208315 (A58376)
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
CASE TV450B SKID STEER (A64279)
CASE TV450B SKID...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
