6ft King kutter tiller ?s
/ 6ft King kutter tiller ?s #1
Foxl3830
Bronze Member
Western PA 15825
Kubota l3830,Ford 8N
Well got a brand new king kutter 6ft tiller today got it home and all have to do is put it together and check oil and grease any one have a king kutter tiller let me know how they worked out an any advice on running them never used one on a 3pt always for the last 15 yrs I rounded up (sprayed grass killer) plowed then disk my plots very time consuming looking to just spray then till plots like I said any advice is welcome thanks hope my tractor can push it ok it's a Kubota L3830 was going to go with a 5ft but my tires are like 65,66" wide was afraid of not being able to cover tire tracks thanks!
/ 6ft King kutter tiller ?s #2
They are real good tiller.......................
Thanks I hope so going to figure out if I have to cut pto shaft or not thanks may make a post on this thanks!
/ 6ft King kutter tiller ?s #4
You should have no issues running a 6' tiller on your L3830 ... we run a 5' KK on our B2910 with no problems.
/ 6ft King kutter tiller ?s #5
Depending on your soil type;you may have to plow then roto-till.Tillers don't like hard ground and grass.I much prefer my tiller over disc's;one pass with the tiller equals 5-6 with the discs.If it has a slip clutch make sure you service it every year(fairly easy job and could save some expensive repairs).
/ 6ft King kutter tiller ?s #6
I run a 5' KK tiller on my 32hp L3200. I ran a subsoiler through to "plow" before I tilled. Probably would have been a LOT harder if I didn't have a HST. If you are underpowered you can go slower, but risk over tilling the soil & turning it to unusable dust.
/ 6ft King kutter tiller ?s #7
I run a 6' KKII tiller on my 34 HP gear tractor, no problem
/ 6ft King kutter tiller ?s #8
King Kutter makes good quality products. Almost bought a 5 footer from Rural King but it's hard to justify spending $1500 for a tool that would be used < an hour per year.
Thanks well figured out I don't have to cut PTO shaft guy at ruralking said if you can't get pto shaft on at level then it should be cut I have like 2"inches Inbetween pto shaft on tiller and tractor and then the spare room once you slide it on the shaft about a total of 3 to 4" inches of space any ideas are apriecated if this is satisfactory owners Manule says about 1/3 of shaft play. Top off all oil and greased all fittings ready to till would have today but has rained and is now snowing yes snowing in NW PA amazing? But supposed to be in the 70s by Thursday and I'm off Thursday and Friday. What do I look for in over tilling when I used my disk for my corn planter it had to be some what fine but not dust in the food plot I'm planting corn we sprayed it for weeds about 2wks ago and all my plots have been worked with in 2 yrs so I believe I won't have to plow but it is true I'd spend hours with 6 ft 3pt disk to get soil worked for planting corn with a massyfergson 2row corn planter hopping to cut that in half hopefully already got neighbors that want there gardens tilled any ideas on how much to charge the one neighbor I'm gonna do for free I hunt on there property ok got go to work to save up for another implement!!!!!
/ 6ft King kutter tiller ?s #10
I bought one this year. I did have to cut a couple of inches off.
I tilled up about 1 1/2 acres. It was pasture/fescue. All I did was mow it real short, then have at it. Work very well.
17601CFL (A59228)
17601CFL (A59228)
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
INOP/NON-RUNNING 2011 Ford F-550 Cab and Chassis Truck, VIN # 1FDUF5GT9BEB33435 (A61165)
INOP/NON-RUNNING...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2008 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59910)
2008 HINO 268 4X2...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
