6520 4WD tire pressure
/ 6520 4WD tire pressure #1
bindian
Super Member
Willis, Texas
Mahindra 6520 4WD
What is the max tire pressure I can run in my Ag tires on front? :confused: The book says 30, but yesterday while moving a whole sweetgun tree I noticed they were almost flat.:eek: I had the trunk caught in the bucket just above the roots and about 40 feet of tree hanging out the other side. :cool: I could feel my rear end, counterweighted with my 511 BH, starting to raise on each bump I went over. Needless to say when I noticed the tires, I dropped the load and pushed it to the burning pile. :(
hugs, Brandi
/ 6520 4WD tire pressure #2
Brandi,
Check the sidewall of the tire for the max pressure. The manual probably shows the recommended tire pressure under normal conditions/use. My manual shows 25.6 psi for the front tire but the sidewall shows 45 psi max.
Joe
/ 6520 4WD tire pressure #3
Brandi,
The max inflation which is marked on the tire is 36 PSI. That says a lot for the power of the loader and a good testimonial for the tractor. And by the way I wish I had speakers on my computer so I could here what you have to say, but I don't and I guess I'm not a good lip reader. Take care and good luck!
/ 6520 4WD tire pressure #4
I filled mine 80% with water and can run at 20psi w/o flattening too bad. Unladen loader /tractor rides better than un filled that have 30psi. I think I may end up filling mine a little fuller on both ends -90%- when I do excavation work, to limit front back tipping. Since its just water I can drain it out when Im done.
larry
LAWALLSTRACTOR said:
Brandi,
Galen,
Thanks. I should have thought about checking the sidewall.:confused: You need to go get speakers to hear it. :rolleyes: Funny thing about that tree I dug up and pushed over in the video. It was the first Sweetgum I have ever seen that had two large tap roots running off to the side. Usually they have one tap root and are easy to "tip" over. ;) It just happened I pushed it over on the second tap root and I didn't see it. Imagine my surprise when I drove around and hooked my loader under that tree trunk and lifted! :eek: I had my right back wheel off the ground before I knew it. Sad to say they deleted that part. :( I would have loved to have seen my face!
hugs, Brandi
GIJOE said:
Brandi,
Joe
Joe,
I just walked out and checked my sidewall. It says 30 psi max. I also checked them. They have about 26 and 28 psi.
hugs, Brandi
larry
Spyderlk,
I just noticed a small sidewall crack on mine. :( I wonder how many times in the past I have lifted something and drove off with it and didn't catch the almost flat tires. :mad: I think I may load my front tires. Any idea how much weight they are filled? I gather from your post above you are stating the tires are stiffer with them filled? :confused: Seems since I bought the Big Red Beast, I have been getting everything supersized. I bought higher weight rated trailer tires, I have been considering trading my Ram 2500 in on a Ram 3500.........and now it might be a case of heftier front tires on the Beast!!! :eek: :cool: :cool: :D
/ 6520 4WD tire pressure #8
Brandi, There is a table somewhere on the forum that gives # @ 75% fill for various sized tires. I have just been assuming 20G/tire, which, with water, would be 160# ea. What size are your tires? I seem to remember theyre a little smaller both ends than the 7520. Youve got AGs? Anyway, Yes a filled tire has less air, therefore the compression ratio is higher as the tire flattens. The pressure will go up quicker as it flattens and keep it from flattening as much. I also like the idea of the added front weight, not supported by the axle, for loader work.
larry
/ 6520 4WD tire pressure #9
The lower weight rating of the ag tires is one of the reasons that I went with R4's. The ags are not intended for use with a FEL. The specs for the 7520 front tires, R1=2320 lbs, R4's=4710 lbs. Different tires have different purposes. Ag tires are made to work out in the field, industrial tires are made for industrial type use. I know that we all use our tractors for many uses, but that doesn't change what the intended use for the type of tire that we each have is. Your R1's were never intended for FEL use. We all have to make due with our decisions. Buy the way, the difference in how the tractor works and feels is literally unbelievable with the tires filled. I filled all 4 tires after the first year and it made a big, big, big difference in traction and stability Fill your tires and you will be much better off in my opinion.;)
Just some more info for you.
Good luck
Good luck
Brian & Spyderlk,
The 6520 and 7520 R4s are the same size, front and rear. The front R1s are a little wider on the 7520 and the rear tires are two inches bigger in diameter on the 7520. I never thought about R1s and R4s having a weight rating difference. :eek: When I was asked what I wanted,,,,,,I was thinking about the muddy work I was going to be doing and was thinking traction only vs. saving turf. I never used a loader before so OOPS.:rolleyes: Thus my R1 choice. I would choose R4s now. But at least now I got higher ground clearance........which is great when I go into a stump hole half filled with dirt to pack it down. :D I think I can fill the fronts and still be under trailer gross weight. Guess I will just fill one and weigh it. Might even fill all and buy a new trailer. ;)
From my owner's manual.........Ag......front........1870 pound rated @ 30 psi
Industrial....front........4710 pound rated @ 46 psi. That is a big difference. The manual says my front axle weighs 2705 pounds, which seems low. Add the FEL weight (approx. 2000 pounds) and what it will lift (3900 pounds:D ) and I am making those front R1s cry hard. That is 8605 pounds. :eek: I love the traction I get with the R1s on front. Guess when these wear out, I will see about finding a higher rated R1. I am sure that would be cheaper than new R4s and rims. I am guessing R4s on front and R1s on the rear would work. But it will look odd. ;) But then,. my Ford 3055 looked odd with those extra bars (English) between the chevrons on the rear.
FYI.......my Mahindra salesman and "his hay crew" just bought a 7520 to pull a baler. He is also the guy who found me 3500 pound rated trailer tires for $105 each. Guess I will go see him Monday and ask for prices on higher rated front R1s. Oh yeah.......my manual says I can fill my tires to 80%.......or the tire valve stem at the one o'clock position. Down here an hour north of Houston, we usually don't have freezing weather more than 8 hours at a time, once or twice a year. I am more worrried about rusting inside the rims than freezing. What is the best solution for not rusting? Sorry if some of this doesn't make sense, as it is Tequila Saturday night. :) :p :)
hugs, Brandi
/ 6520 4WD tire pressure #11
My 6000 came with R1s filled with non toxic RV type antifreeze. I have done exactly what you are doing for going on five years now with my 6000 and R1s. Don't doubt the sturdiness of the tires. I'll take the traction over the load capacity. Why? I'm already hauling everything I can counterweighted (and sometimes lifting the wheels) with no tire issues. The Mahindra loaders might be a little slow to some, but man do they lift. I'll just keep on doing all I do with my R1s and when they wear out I'll get new R1s.
/ 6520 4WD tire pressure #12
bindian said:
Brian & Spyderlk,
Guess when these wear out, I will see about finding a higher rated R1. I am sure that would be cheaper than new R4s and rims. I am guessing R4s on front and R1s on the rear would work. But it will look odd. ;) hugs, Brandi
I really wouldn't try R4s in the front and R1s in the back..different profiles, and gear ratios will make "something" wear faster......6000 comes with 11.2x24s in the front...My FEL will also do the 3900lbs...never had an issue with "flattening" fronts.. Not sure if the 11.2s will fit on your rims, but would be worth the time to ask....BobG in VA
/ 6520 4WD tire pressure #13
Brandi and Brian, I like the predominate advantage of the self cleaning tire for traction in most situations, as well as the larger diameter too - which also helps traction and ride quality, and ground clearance. It is for these advantages that I would never go to R4s, perhaps even if I were doing 100% loader work on surface conditions here. Admittedly, the fronts become grossly overloaded when carrying full loader capacity. Lets see- tractor,BH,FEL, loaded rears--12,000#... bucket load 4000#. The rears get light. That means theres somewhat less than 16K# on the fronts. At unladen fill 30psi air the tires are near flat. The question for me is what pressure the tire will safely accommodate. The side panel on both the rear and front tires gives warnings about using more than 35psi to seat the bead. Yet the max operating pressure of the rears is 18psi, while the front is 30psi. This is inconsistent with logic for differently sized tires having 6 ply rated carcasses. Due to its smaller size and therefore lesser area the small carcass is not strained as much per psi as the larger one. I know for a fact that the fronts will withstand 80psi because I accidently got one to that by leaving the water on too long while in the last fill - bleed cycle. There wasnt much air in it so not super dangerous. That low compressable content is whats so good about making the R1 work safely for much higher loads. My tires now have 16psi. I initially set them at 20, but some of the air has been absorbed into the water. The tires ride better, and carry loads better than they did empty at 30psi. They are filled to just above the valves at 12 oclock - a little less than 75%. I plan to keep pressure in the 18 to 20psi range and go as high as 90% fill to get load support. The pressure will go higher with squat from FEL load - maybe as high as 50 with care on bumps- but Ill be far from the tire. I know the carcass will stand 80psi, and the benefit of limiting the extreme [and harmful] distortion seen by the 30psi empty tire is worth it to me. Another way, if you could be sure youll never change your mind, would be to foam fill. For me -too permanent.
Brandi, yes rust is an issue, but the rims are painted. Even CaCl leaks take years to rust out a rim. Even in freezing territory I choose water for convenience. I keep shaving trees with the rims and that causes a bead leak until you remove the morsel. Its great to be able to just let some water out to soften the tire so that it comes out easily and completely. Or you could just let it seep for awhile - no big deal.
larry
/ 6520 4WD tire pressure #14
Bob, I have 11.2s and @ 30psi they flatten on 7520 at full FEL load. You may have a longer wheelbase or else less front over reach with the loader. Thats the only thing I can think of.
larry
BobG,
Now that has me puzzled.:confused: My R1s on my 6520 are just 9.5 x24s. Why would they put a narrow tire on the 6000? :confused: :confused: When it will lift the same as your 6500? :confused: :confused: :confused:
hugs, Brandi
/ 6520 4WD tire pressure #16
bindian said:
BobG,
hugs, Brandi
That would be to match front/back circumferences to the 4wd axle ratio.
larry
larry
Ok, I understand now. It wouldn't matter what was (is) in front on a 2WD.
hugs, Brandi
/ 6520 4WD tire pressure #18
Brandi,
Can't seem to locate it just this minute, but there are tables for the various tire sizes and what they take in water weight (and/or water/methanol mix) at various fill %ages. Might try googling "water filled tires" and see what you can find.
My 6500 fronts worked out to about 250# each with water/methanol mix if I remember correctly.
VistanTN said:
Brandi,
VistanTN,
I will google it. :)
hugs, Brandi
