6405 front pull point
/ 6405 front pull point #1
Turkeyman
Columbia, SC
JD 4720 and 5075M
I stuck a 6405 MFD tractor and will try pulling it out with a 5320 or a backhoe. When I pull from the front can I hook up to the front axel as their appears to be no other place to hook to?
If I can remove the disk, I will try pulling from the drawbar. I will use a chain or a tug strap.
Thank you
/ 6405 front pull point #2
Try pulling from thr front axle pivot point. That is the strongest area on the front unless you have a front weight bracket to attach to.
/ 6405 front pull point #3
My first choice would be the center pin of a front starter weight.
Second would be front axle pivot
The ground in front of it was too soft, so after moving the disk I took the backhoe and dug down and pulled it our slowly with a chain around the rear axel. Thank you for the suggestions and help.
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
2002 Sterling L7500 Series VacCon Combination Sewer Jetter Vacuum Truck (A64556)
2002 Sterling...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
2022 EZ-GO ELITE...
