6405 front pull point
/ 6405 front pull point #1
Turkeyman
Columbia, SC
JD 4720 and 5075M
I stuck a 6405 MFD tractor and will try pulling it out with a 5320 or a backhoe. When I pull from the front can I hook up to the front axel as their appears to be no other place to hook to?
If I can remove the disk, I will try pulling from the drawbar. I will use a chain or a tug strap.
Thank you
/ 6405 front pull point #2
Try pulling from thr front axle pivot point. That is the strongest area on the front unless you have a front weight bracket to attach to.
/ 6405 front pull point #3
My first choice would be the center pin of a front starter weight.
Second would be front axle pivot
The ground in front of it was too soft, so after moving the disk I took the backhoe and dug down and pulled it our slowly with a chain around the rear axel. Thank you for the suggestions and help.
6 Ratchet Straps (A65579)
6 Ratchet Straps...
New/Unused CFG Industrial MX12RX Mini Excavator (A65583)
New/Unused CFG...
2022 EZ-GO ELITE...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
2012 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2012 CM TRAILER...
2013 Hitachi ZX160LC-5N Hydraulic Excavator (A64553)
2013 Hitachi...
