6110 cab AC
/ 6110 cab AC #1
PawpawScooter
Mahindra 6110 cab
Clutch locking up
Belt squealing….. belt is tight.
/ 6110 cab AC
Sorry first time user….. ac runs gets cold then belt starts squealing. Clutch locks up after running a few minutes.
/ 6110 cab AC #6
No I will do that..thanks
Actually, clean the condenser which will be under the hood and in front of the radiator and clean the radiator as well. I use Dawn dish wash detergent in a spritz bottle mixed with water after blowing them out with compressed air (at less than 50 psi because high pressure air will deform the fins. I actually clean everything under the hood every day I use the tractors with a battery powered blower (I use a Harbor Freight Bauer, hand held 20 volt blower). Cheap and work quite well.
Then clean the evaporator (don't know where yours is located at), mine is over my head, under the removable roof.
2014 Crane Carrier Co. Low Entry T/A Rear Loader Garbage Truck (A66736)
2014 Crane Carrier...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
Unused 2025 USA Attachments Quick Coupler Excavator Attachment (A66734)
Unused 2025 USA...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
1998 CAT 938G WHEEL LOADER (A67714)
1998 CAT 938G...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
