60 inch mmm
/ 60 inch mmm #1
automech
SE PA
bx1500
I am thinking about trading up to a BX2230 and was wondering if I should go with a 54 or 60 inch deck. Does the 60 have a tendency to scalp or clump? I have a hilly yard with some swayles here and there, lumps etc.(the yard is not golf course material). I have a 54 on a smaller BX now and it seems to work ok. How well does the 60 work with a bagger set up? Would it be a mistake to buy the 54 for the larger machine?
/ 60 inch mmm #2
I have a 62" mmm on my JD 2210 and I have no issues with scalping. My property is hilly and has some ruts. The only issue you may have is fitting through gates or garage doors. If you do not have an issue with storage, I would get the larger deck.
/ 60 inch mmm #3
Do you have enough room to manoeuvre a 60" deck around trees, gardens, doorways, etc.? If so, the 60" deck will give you about a 10% increase in productivity. I doubt that there would be any difference in scalping, etc. Similarly, I can't see why there would be any difference in bagger performance. /forums/images/graemlins/smile.gif
/ 60 inch mmm #4
Automech,
You may want to post this in the Kubota forum. If I remember right the 60" was actually a different mower and did a much nicer job. Again I am going by memory and at my age there isn't much there but I do remember some discussion about this in the Kubota section.
murph
2007 JLG G6-42A 6,600lb 4x4 Rough Terrain Telehandler (A64553)
2007 JLG G6-42A...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
2000 Caterpillar V300B 30,000lb Rough Terrain Forklift (A64553)
2000 Caterpillar...
2013 Ford Taurus Sedan (A64557)
2013 Ford Taurus...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
