Backhoe 60 Hour report on B7610 and backhoe
   / 60 Hour report on B7610 and backhoe #1
v8dave
Platinum Member
Northern, Calif.
Kubota 7610
Here is a 60 hour report on my Kubota B7610 TLB. Started out as a 50 hour report several months ago, but time seemed to get away.
I bought this tractor for some extensive landscape and construction work at our home in the foothills of California’s Sierra Nevada Mountains. It is equipped with a LA352 loader, B4672 Backhoe (12” bucket), a Gearmore box scraper, R4 tires, and top ‘n tilt controls. The dealer filled the tires and welded two chain hooks to the loader. I also have a cutting bar for the loader bucket. The work being done hasn’t needed the scraper or cutting bar--yet. I put the first 50 hours on in five months and only 10 in the next seven months. Something about you don’t need a tractor too much to do the finish work on a shop.
I had the dealer weld the chain hooks on the bucket mostly because of TBN posters saying how useful they were. I had no idea what to use ‘em for, but I got them anyway. Turns out they have been real handy for boulders. The boulders have been too big to fit completely in the loader. So, I get the lower lip of the bucket under the boulder and loop a chain around ‘em and tilt back to grab the boulder. About half the time the boulders drop into the bucket and seem secure. But, just to be sure, the chain gets readjusted to keep it there while being transported. About 200 boulders were moved with this approach. I’ve been amazed at the size of the boulders the LA352 loader can pick up.
I’m gaining experience in smooth operating of the backhoe. While swinging back from the spoils pile, I can now also operating several other functions at the same time, i.e., start extending the boom, dipper and bucket for the next scoop of material. This multiple use diverts some of the hydraulic fluid away from the swing and makes it much smoother to operate. On the occasions I use the swing alone I notice the operation gets jerky. The left-right operation of the joy stick [for boom swing] is less natural than forward-backward, of the other controls, for the really fine feathering of the joy stick valves necessary for smoother operation.
I choose to run the backhoe with the tractor engine at rated PTO speed. When run slower, the time to move the bucket between the hole and the dump pile takes too long. It’s not going to wear this tractor out in my life-time of homeowner use.
On the humorous side, I caught myself pulling real hard on the backhoe controls in tough digging--to try and “help” the tractor dig. It doesn’t seem to help the tractor much and it does wear me out, I got a stiff neck, sore shoulders and back. I’ve learned to ease-up on the controls, it makes the whole job easier.
Operating at the tractor at anything above 1,500 rpm, I use hearing protection. I already have a hearing loss and don’t wish to make it any worse. For all practical purposes this means as soon as the tractor is moved to a work location hearing protectors go on. I use alternately a hard had with ear muffs or soft plugs in the ear channel. The hard hat with the muffs is used whenever I have somebody else around and have to talk to them. I can lift a muff easily to hear. But, after a while the clamp on the ears gets tiring. So, when I don’t have to talk and listen much I use the plugs, for me they are more comfortable for multiple hour use.
Lubricating the tractor after each ten hours of operation uses up the grease. Each fitting takes at least two pumps. There are 11 or 12 fittings on the backhoe and 12 on the loader. It’s a minor thing but you need to plan ahead and have some spare cartridges available. Because some joint pins are tight it’s necessary to hold the grease gun coupler on the tractor Zerk fitting to get the grease in. My grease gun had a flexible hose between the gun and the Zerk coupler. It was awkward to use at times because you need to use both hands to work the pump and a third hand to hold the coupler on the Zerk fitting. I placed a rigid connector on the grease gun. That way I can force the connector on the Zerk while working the pump with the normal set of two hands.
I am now used to getting on and off the tractor and have mostly stopped snagging pockets and jackets on the tractor’s posts and levers. Since putting on the TNT, its controls further crowd the right side of the tractor. So, I mostly use the left side to board and exit the tractor.
I finally stopped driving off with the parking brake still set [on]. I attribute that to the always using the brake when stopped and therefore getting used to setting and releasing it. I also can tell by the engine sound the brake is still on--right away--when I drive off with the brake still on. Even with the hearing protection in/on.
I broke one of the three point lower tie chains. The dealer replaced it under warranty. The chains were a pain to adjust and I liked the TBN posts about changing to a drawbar set-up. So, I ordered $105.00 worth of B2910 parts from TractorSmart and replaced the chains with a drawbar.
Super UDT is specified for use in the transmission/hydraulic system. My dealer put UDT in instead of Super UDT at the 50 hour service. Later, I noticed a loss of power in the front loader. I couldn’t lift boulders I had previously lifted and moved, when it came time to move them again. The dealer made good with replacing the UDT with Super UDT. I can now lift the boulders again, but not as easy as I recall it was before. Let me clarify a point though, these boulders clearly weigh more than the rated capacity of the loader. The tractor loader quite easily lifted and moved a generator set on a chain sling hanging from the bucket. The generator set weighed nearly the “rated” capacity of the bucket. Maybe it isn’t the SUDT vs UDT. Maybe I’ve just broke in the seals, pump and pressure release valve. Maybe it was cooler/hotter day, maybe a full moon, who knows? But you know, I got used to that extra capacity and I’d like it back again.
As noted by lots of TBN posters, a cup holder would be real nice. I’ve also come to appreciate the need for a chain bucket. One of these days those are going to be fabricated and added.
   / 60 Hour report on B7610 and backhoe #2
Dave-
Thanks for the great post. I echo many of your observations (especially regarding the BH) and will probably agree with the rest of your comments as I log more hours on my tractor. I too will definately need places to put my chains and work gloves (lost one in the mud somewhere next to my driveway).
Once again, thanks for the useful post.
Bonehead
   / 60 Hour report on B7610 and backhoe #3
Excellent write up, thank you.
For the drink holder I built one out of a piece of PVC pipe. Used copper wire and "laced" back and forth through some holes I drilled about 1/2" from the bottom of the piece of pipe and used a pipe clamp from Lowe's electrical department to hold it to the loader crossbar.
Since taking the pictures I added a screw through the pipe clamp and into the crossbar to hold it in place better.
Pictures at drink holder, grille bruch guard, and hydraulic line protector
Bill Tolle
   / 60 Hour report on B7610 and backhoe #4
v8Dave ...... Excellent job on that report, it should be helpful for those
just starting to use their first BH. I know I was looking for help when
I first was getting aquainted with mine. /forums/images/graemlins/shocked.gif I found an ammo can
very useful as a chain box and glovebox on my rig /forums/images/graemlins/smile.gif see pix ....RayBee
Bill, thanks for the pictures of the cup holder. I can see how you've "woven" the wire through the base. The way you've done yours I can easily duplicate. If I had a PVC pipe or scrap the size you show, it would already be in progress. I used up all my 3" pipe in plumbing out the drains for the shop. I'm going to check the left over fittings box tomorrow and see if there isn't a short piece in the box. I hate to buy a 10' length just to saw off 4", although I might just do that.
By-the-way, I've taken to drinking Gator Aid (or Costco equivalent) too when working on hot days (I think that's what you show in the cup holder). It seems to keep me going better than an equivalent amount of water. Although on really hot days I still drink more water than gator aid.
RayBee, I bought an Ammo box to use as a tool box on the tractor like you show. In fact I got several sizes of ammo boxes. I don't have the room like you do to put one on the backhoe frame.
Not much space to available to bolt one of these boxes down. I thought sure the smaller ammo box could bolt down to a flat area somewhere. But, I was wrong. I'll probably have to fabricate a bracket for the loader post and place the ammo box on the right side for use as a tool box and I'll put something else on the left side loader post for the chains. A 4" length of 3" or 4" square tubing would work well as a chain bucket. Another TBN member posted a thread on this approach. I just haven't been to the surplus metal store in a while though. One of these days. . .
   / 60 Hour report on B7610 and backhoe #7
Good and useful comments. Thanks for taking the time to type them up. This kind of first hand general comment is what drew me into TBN in the first place and it's always good to see an addition to the collective wisdom.
Cliff
   / 60 Hour report on B7610 and backhoe #8
v8dave,
Good article.
I've 50 hrs on my 7610 TLB and have shared many of your experiences. The BH trick of cracking the crowd or curl cylinder while swinging almost makes it look like I know what I'm doing. /forums/images/graemlins/smile.gif
I still need to weld hooks on the bucket. It's high on the LIST.
You mention hearing protection above 1500 rpm. I've got a question for you. I find the engine to be rather quiet, but the HST to scream loudly. I brought this to my dealer's attention (over the phone around hr 1), and he didn't seem concerned. I'll be dropping the tractor off for 50 hr service soon, and will revisit the issue. So the question is this...Which is louder, your engine or the trans?
Thanks, edski
   / 60 Hour report on B7610 and backhoe #9
Very nice report, I would seriously recommend the use of SuperUDT only in your rig though.
Edski, I have run my B7610 a lot for backhoe use. Which, I generally run at PTO speed--and that is quite noisy.
I haven't done a lot of long shuffle trips with the loader. So, I haven't noticed the HST whine too much. And, when I do make loader trips thay tend to be short and slow trips. There is almost no level land at my place so mostly I drive on pathways I've cut and they aren't smooth enough or long enough for travel in other than low gear.
Although, I did notice the noise level was up when I was moving several truck loads of gravel with the front loader. I attributed that to the fact that I had the throttle up almost all the way to be able to dive into the gravel piles and load the bucket fully on the first pass.
I'm just super cautious about my hearing and don't take any chances about further loss.
   / 60 Hour report on B7610 and backhoe #11
Senor Edski-
Put me down as one vote for the trans. I am generally very good at wearing ear and eye pro when working outside with power tools, lawn tractors, etc but must admit that I don't find the 7610 engine to be loud at all. The trans whine gets to me after a while though, which is a good thing as it forces me to use my ear protection.
On a somewhat (OK, only kinda) related note: According to the manual, you should not operate the engine "at speeds faster than necessary" during the first 50 hours. I have taken this to mean below 2000 rpm. Can someone tell me what "faster than necessary" means?
Bonehead
I ran my B7610 at lower engine speeds for the first 25 to 30 hours. I don't remember exactly at what speeds but initially around 2,000 then probably 2,200 to 2,300. But, as I gained experience with both the loader and backhoe, I started running the engine faster. By 40 hours, I was running the backhoe at PTO speed except in really easy digging situations--that means it doesn't run slow very much.
Due to the irregular surface, I noted above, I drive around with the engine speed set at 1,500 to 1,800, much less and it works too hard or stalls on the up hill driving.
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2006 Ford E-350 Enclosed Service Van (A59230)
2006 Ford E-350...
FUTURE 6' CLIP-ON FORK EXTENSIONS (A60432)
FUTURE 6' CLIP-ON...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
