6 leaf slipper spring suspension ??
/ 6 leaf slipper spring suspension ?? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
I am going to buy a PJ trailer (20ft)this weekend per my previous post.Could someone please enlighten me on what a 6 leaf slipper spring suspension is?How does it compare to a torsion suspension?Thanks for any information.coobie
/ 6 leaf slipper spring suspension ?? #2
The slipper spring suspension is the usual spring suspension installed on larger trailers. The leading edge of the spring leaf is attached to the spring hanger with a bolt. The trailing edge is an extended leaf that is not attached with a bolt. As the spring flexes the trailing edge slides along the spring hanger. This system works very well. I have it on my cattle trailer ('81 model) and my dual tandem flatbed ('99 model with 12,000# axles).
I've heard good and bad about the torsion axle. It's really an independent suspension. Each wheel and axle stub moves independently. The axle stub is mounted inside the axle tube with rubber. With time the rubber can wear out.
Thanks for the info JESSE1,I just sold my 16ft hurst trailer,it has the torsion axle(3500 lbs axles).The new PJ trailer (20ft.)has 7000 lbs axles with the slipper suspension.I have never heard of a slipper susp.before,thanks.coobie
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
2025 SDlanch SDLD25 (A64127)
2025 SDlanch...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
