580D Steering
/ 580D Steering #1
jsmiller1306
Macon, Mo
John Deere 4720
I have a 580D with steering problems and I have never worked on this style of steering. when your driving sometimes you loose all steering to the RH and the wheel free spins, but if you jurk the wheel to the LH you get steering back. If anyone has a good ideas it would be nice. thanks
/ 580D Steering #2
Power steering fluid ok?
/ 580D Steering #4
On second thought, I think you may have a power steering that works off the hydraulic pump. On the bottom end off the steering wheel may be the pump with 2 hydraulic hoses connected to it. If that is what you have, then either the hydraulic fluid is low, or you have to take the pump out take it apart and clean it.
/ 580D Steering #5
One of your steering cylinders likely has a blown seal. My 580D did the same thing. Steering would just stop and the steering wheel will freely spin all the time. It's probably one side but I resealed both sides at the same time. Not that big a job; can be done with basic hand tools. Kits are about $25 each online.
My steering now is very positive and hits the relief valve at the steering stop.
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2017 Kenworth T680 (A64127)
2017 Kenworth T680...
John Deere 925 Cultamulcher (A66408)
John Deere 925...
2023 Blue Diamond 103030 Extreme Duty Cutter (A65640)
2023 Blue Diamond...
2021 SANY SY26U EXCAVATOR (A63276)
2021 SANY SY26U...
2008 Harley Davidson Motorcycle (A64127)
2008 Harley...
