580c pto
/ 580c pto #1
spo307
Levittown & Long Eddy NY
kubota L4400
hello new jack here, I am looking at a early 80,s case 580c, my question is can the backhoe be removed and a brush hog type pto mower be hooked up? he is asking $7500, says it smokes when first started in cold, couple of pistons need to be repacked, I have 55 acres and am looking to putz around, replant trees, shuttle dirt and rocks, etc what do you think, thanks for your opinions and help.
/ 580c pto #2
Even if there was a rear PTO shaft on it, I would guess it would be kinda
hard to connect because there's no 3 point hitch.
Most "real backhoe loaders" have neither of these.
-Mike
/ 580c pto #3
A 3pt hitch was an available option but it would be cost prohibitive to add now.
You'd need to have the frame that the 3point mounts on, the links, and the 5 or 6 lever control bank. They have a built in top and tilt. The add on pto was hydraulic. I dunno if any of these parts are still available outside of service items like the hydraulic cylinders... You can look at the parts books and diagrams on CNH.com/.
Looks like a pretty good tractor. I don't remeber if the C series got the 188 case or the 207 case. My 580D smokes a little on startup and it's newly rebuilt. The cylinder seal kits are only about $20ish. Takes about 1-2 hrs if your first time. Less with practice. I'm currently doing this on my D. One down and one to go. I'll post some pics when I get em out of my camera.
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
Prime 604 Dirt Pan (A64047)
Prime 604 Dirt Pan...
2007 MACK CXN VISION (INOPERABLE) (A63569)
2007 MACK CXN...
ATS ME18 Mini Excavator (A64047)
ATS ME18 Mini...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
