58 Ford 861 Return Fuel Line
/ 58 Ford 861 Return Fuel Line #1
jtmcdon
Bronze Member
Oxford, GA
Ford/861D
I have an early model either a 57 or 58 Ford 861D and it has only one return fuel line from the standpipe to the brass fitting that screws into the side of the block. I understand in 1959 and later Ford started using a standpipe with two return lines.
Other than cost can someone tell me the difference between part #311309 and part #B9NN6A035B? The fuel line on my tractor right now is a braided flexible line but the suppliers I spoke with are telling me their lines are steel. One supplier had both in stock but there is a big price difference between the two. Also, the length of the lines are different. I was told part #311309 was about 12" long and part #B9NN6A035B is about 19" long, which is the same length as my flexible line. He also told me part #B9NN6A035B was smaller in diameter.
Any help is appreciated.
Thanks. Tom
/ 58 Ford 861 Return Fuel Line #2
Are you talking about the fuel line from the tank to the injection pump?
/ 58 Ford 861 Return Fuel Line #3
The high pressure fuel delivery line from the pump to the injector is steel. The fuel return line on my '63 2000 is a rubber hose. The fuel return line on my '65 is a pre formed plastic assembly. The fuel return line goes back to the pump and off to the fuel tank which is vented. There essentially isn't/can't be any kind of pressure on that line (to speak of) with routing back to the fuel tank
