Xfaxman
Super Star Member
- Joined
- Feb 8, 2013
- Messages
- 13,321
- Location
- Guthrie, OK
- Tractor
- Toolcat 5610 G - Bobcat V417 - TORO+Loader
Thanks. I run a 6 ft on my series A. Lot more hills than you have. Any trouble with hydraulics heating up?
Yep, I see your hills!Had to replace 2 drive motors. Just got it back today. Bush hogged for 3 hr. Worked great and never overheated in the 90 degree plus temp.
Looks like a good one and l agree about the mower out front. :thumbsup:I got a 5' brush monster for my 5610 F
Skid Steer Cutters, Rotary Brush Cutters, Skid-Steer mowers from BRUSHMONSTER - Now Available 12-month 0% financing
The front mounted bushog works great. I have used it mainly to clear paths through the woods, cut small trees. Great for clearing out around a big tree you are getting ready to cut. Does not have front wheel, but has raised front end like funnel so you can push trees over with it. It pushes the tree a little and then the blade whacks it off. Will turn woods into flat clear ground pretty quick and it mulches everything to some degree. Way better than rear mounted bush hog where you have to drive over everything before you cut it.
My 7' wide Rotary Mower is rated "up to 4 inches", but I usually pull the 3 and 4 inchers with the tree puller on the V417.What size saplings can you effectively take down with these rotary cutters?
The "stumps" are splintered and not sharp and no problem for the 8 ply tires.Do you ever worry about sharp "stumps" puncturing the tires? I often mow in reverse, because I'm not comfortable running over some of the larger stuff I cut first, and sometimes worry about the small stumps left, but so far no problem.
These are impressive setups for sure! Best part is, you can bring someone along for the ride!
What is the lift capacity on the 5610? How about the pressure and flow with the high flow hydraulics?
I think most tree shears weigh less than my brush hog.That is some very impressive hydraulic power! I know I've asked about your equipment before, but I didn't realize it had that much hydraulic hp. You could easily run almost any skidsteer implement.
I wonder if this could handle a tree shear? I suppose weight would be the limiting factor, I think those are fairly heavy.
I did a little craigslist searching and I'm quite certain that one of these might bit a wee bit out of my budget, but maybe one day I'll get to go for a ride in one and try one out.
Very impressive to say the least.
When I saw the title I was expecting to see a big blue tractor, lol
Like this one? <img src="http://www.tractorbynet.com/forums/files/toolcat/405527-5610-cutting-brush-1308-jpg"/> Pictures from Google Image Search.
