5525 Failed Steering Line
/ 5525 Failed Steering Line #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I lost a line this weekend. The one for turning left. It chafed thru on the frame. It looks like it was installed wrong. Everybody might want to check their lines. It happened where the axle pivots on the frame.
D.
/ 5525 Failed Steering Line #2
I'll check it out on mine! Thanks for the heads up.
Did you ever get a recall notice on the steering for your tractor? I got one on my 5425. Still need to get that taken care of too.
No, I will call and ask about it. Any idea what it was to address?
D.
/ 5525 Failed Steering Line #4
Can't remember off the top of my head. Just remember it had to do something with the steering hydraulics.
I asked my dealer. That recall is about a cylinder. Some 5x25s have the same as on the 5603. They are recalling them for some reason. My 5525 was not included in the recall.
Thanks,
D.
/ 5525 Failed Steering Line #6
Just got a call from my dealer. The part is in and they'll send someone to install it next week. :D No fuss, no muss!
/ 5525 Failed Steering Line #7
it's a mandatory safety pip kit. there is a miniscule chance corrosion is in your steering cylinder from the factory causing the cylinder to fail and lose steering capability.
dealer should install a new steering cylinder if your machine falls in the serial number range
Wolverine DB-15-84W 84" QA Angle Blade (A64912)
Wolverine...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
2009 FORD E150 CARGO VAN (A66091)
2009 FORD E150...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2002 FORD E350 CARGO VAN (A66091)
2002 FORD E350...
2021 Ideal BB4LD 48in. Box Blade Tractor Attachment (A66734)
2021 Ideal BB4LD...
