5520 john deere tractor
/ 5520 john deere tractor #1
vealsff
murfreesboro,tn.
5520 john deere
john deere 5520 clutch release bearings fried. fingers on clutch fried. replaced all. now tractor will not move what is the length to set the clutch fingers please help. I can shift gears with out using clutch. pto gear works fine. vealsff@comcast.net or can it be something in the transmission
/ 5520 john deere tractor #2
Did you buy the whole clutch? If it was entire clutch then you don't have to adjust the fingers it's already set. Did you adjust your clutch pedal linkage ?
/ 5520 john deere tractor #3
which transmission do you have?
/ 5520 john deere tractor #4
I'm guessing it's a power reverser. What last 6 of your serial number
/ 5520 john deere tractor #5
I'm guessing the power reverser. What's last 6 of your serial number?
