550xp first tank ...
/ 550xp first tank ... #21
So whats the deal with the diagnostic tool for the new autotunes? Can you make any adjustments like max rpm? I know you can test the fuel solenoids, get runtimes and "reset" the computer so it will re-learn if you do any mods, but what else can it do, what data can you pull form the computer and is it necessary for routine maintenance?
Im really liking the 550, but not if a $250 diag tool is required for ongoing maintenance or minor mods.
The diag tool is not needed for the 'normal' guy. Only for extreme chainsaw nuts. :D
/ 550xp first tank ... #24
The reviews on the 562 and 550 sound good. But I must say I am not ready to buy a computerized chain saw yet. Of course I have no desire to buy a tier 4 diesel tractor either. That is precisely why I upgraded several pieces of my equipment, including chain saws, before all this technology is all you can buy. These are tools that I plan on having a good while, I want stuff I can fix most of the problems myself.
/ 550xp first tank ... #25
It's a tool to diagnose auto tune saws with problems. Reset computer, etc.
Oh yeah, I understand that. But what is the actual information it can provide?
Does it give RPM while running? Can it store or generate error codes? Give troubleshooting suggestions? Can you modify the fuel curve?
Seems to me it would just provide the bare minimums. There are no sensors on the engine are there? Like O2?
Scoob , I just got the thing today . I'll let you know exactly what it does as I get used to using it .
But , you don't need one to own and run the 5 series saws , I'm just kind of a dweeb on getting new stuff .
I can't afford fast cars , airplanes , boats , or women , so I picked up the bad habit of being interested in saws. I'm pretty sure that if they come out with a 590 xp or a 595xp , I'll be sorely tempted . Heck , I'm debating getting a ms460r before they go away even though I don't like the dealer at all . ;-)
Nixon you will have less headaches from saws than women would be my 2 cents worth
On the off chance that my wife could read this forum , you really don't think I'm going to answer that statement , do you ? ;<)
/ 550xp first tank ... #29
Nixon, I think saws are cheaper than women... A chainsaw cant take half your stuff:D
I look forward to the update on the saw computer's capabilities, thanks
/ 550xp first tank ... #30
See you already know the right answer if you are married Nixon.. I was married for a long while and not right now so I can get away with the statements.
So far , so good ! Had a small warm restart issue , it was the operator , not the saw . You be amazed what can be learned from reading the operators manual ! :) going in search of a laptop tomorrow ,as everything I have is Mac ,and the analyzer doesn't speak Mac .
/ 550xp first tank ... #33
No DON"T go PC save the MAC! Some of the Macs you can boot up in PC mode or emulate that.. Yeah I just picked up a Dolmar the other day and actually read the manual.. Geez I must be getting old....
No DON"T go PC save the MAC! Some of the Macs you can boot up in PC mode or emulate that...
I hear you. But, for some odd reason I don't think having my saws up in the office of SWMBO would be received well . :) Picked up a small HP that I can use down in the shop , or in an emergency.... The dog house .
/ 550xp first tank ... #35
Nixon, I think I had the same warm start issue on my 562
Saw wasnt hot but warm. Probably sat for 10 minutes while I cleared rounds from out from underfoot
Followed this procedure:
Warm engine
Start position (1): Set the start/stop switch in the choke
position by pulling the red control outward - upward. Then
immediately press down on the start/stop switch to attain
start throttle setting.
Decompression valve (2): Press the valve to reduce the
pressure in the cylinder and make starting easier. Once
the machine has started the valve will automatically return
to its original setting.
Air purge (3): Press the air purge diaphragm repeatedly
until fuel begins to fill the diaphragm (about 6 times). The
diaphragm need not be completely filled.
I didnt do step 3 because there was fuel in the bulb. I didnt want to flood it. Should I have primed anyways?
Saw took probably a dozen pulls to start. I smelled raw fuel. I know I flooded it somehow?
What am I doing wrong? I watched lots of guys on youtube starting it in less than a single full pull of the starter... any ideas?
/ 550xp first tank ... #36
Warm engine
Pressing the bulb will not flood the saw, It purges the air out of the system. Press the bulb a few times next time. ;)
Jason , my problem stemmed from not going to high idle to restart warm . As blue gill 2 says, I don't think pressing the primer will cause flooding . So , if it's flooding , I have no idea as to why. If it does it again , pull the plug and see if it's wet.
/ 550xp first tank ... #38
ill prime it next time. If I have an issue Ill pull the plug and see.
Jason , I've only played with the diagnostic tool for a while , so don't take every thing I say as gospel .
First , it's not needed for routine maintenance . It tells I you if the various sensors are functioning to specs , tells you max rpm , what percent of time the saw has spent at various rims and throttle settings ,carb temps ..... And I can't remember the rest :)
How are you liking your 562 ? Loving mine , but I'm bugging the dealer to get me an updated harness so that I can get at the plugs like on the newer 562s .
/ 550xp first tank ... #40
Absolutely loving the 562. I havent ran it in a couple days so I havent had a chance to try any tricks to improve the warm start performance. I know I'll get it figured and have it starting proper.
There is a link on 0ne of the Swedish chainsaw sites that talks about the diag tool and its functions. Was if you that posted the link on Hearth to the site? (I think it was hearth?) Cant remember now.
But i can see some requirement for the computer even by the typical owner/mechanic. Things like a leaky intake or fuel delivery problem will upset the computer, making it learn and adapt to the problem.. Then once you FIX the problem the computer doesnt recognize the repair and continues to behave as if the fix never happened. This will require a reboot on the saw computer, however as it is now, I dont think you can do it without the factory Husky interface box. This is precisely the thing that scared me about Autotune.. No way to force a reboot without the computer box. At least on a car you can always unplug the battery if you had to.
Here's hoping for an aftermarket hack (or workaround as I understand they had for AT v.1.0 ) that can connect to the AT
2014 Keystone Passport 3220BH (A62613)
2014 Keystone...
20ft Jumper Cables (A65583)
20ft Jumper Cables...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
5 Wheel Hay Rake (A65640)
5 Wheel Hay Rake...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2011 Ford E-350 Passenger Van (A64556)
2011 Ford E-350...
