5435 Transmission Problem
/ 5435 Transmission Problem #1
chade1968
5435 Massey Fergeson
The tractor has about 1000 hours on it and it has the following problems:
The speedshift light moves from C to D but the stays in D - only the light changes no change in speed
The tractor is reluctant to shift unless it is in D
The reverse is now starting to make a noise
The filter under the footrest on the left side (the 60 micron) has had to be replaced 2 times (the light came on and went off after I changed it). I looked closely at the fluid and could not see any debris however the fluid I blew out was a little dark in color.
Any ideas?????
Well she ground to a halt today... great just in time for winter. 1000 hours and dead. Shoulda bought the JD.
/ 5435 Transmission Problem #4
Did the problem get fixed last time or has it been doing it right along?
When you say it's dead, won't move? does it run?
/ 5435 Transmission Problem #5
Mines got 4300 hours without troubles, so it isn't the tractor per say. I'm guessing a clutch burned up or a seal broke. Where you using the speedshift to downshift holding a load? That kills them in no time, sticker right on the door telling you not to.
If its shifting hard in C, likely a seal is leaking the transmission circuits fluid so the main clutch can't operate. The transmission gets a fraction of the pump flow to operate everything including the fwd /rev clutches, speedshift, range change etc.
I'd go to Machinery - British Farming Forum
They have a lot of MF 5400 series over there.
Any ideas?????
