5420 John Deere hydraulic problem
/ 5420 John Deere hydraulic problem #1
Les Keim
John Deere5420
I have a 5420 and 1 of the hydraulic pairs in the back is not working. I have only had the tractor for a year and it may not have even worked when I bought. both sets work fine in the front operationg the bucket and one set is fine in the back. Is there a lever I have over looking or does this sound like a bigger problem. Thx
/ 5420 John Deere hydraulic problem #2
The 5205 JD has levers controlling rear hydros near where your lever for the three point hitch is. I hope that helps I am no expert.
/ 5420 John Deere hydraulic problem #3
Are you saying that there is no fluid flow out of the valves. Does the 3pt work. Plug in a gage and activate a lever, and see if there is any pressure. Maybe you have the wrong QD's. Need matching pair for correct mating .
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A64553)
2006 Generac...
UNUSED FUTURE XDM43-43" HYD DISC MULCHER (A65055)
UNUSED FUTURE...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A64557)
1999 22ft Sea Ray...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
2022 EZ-GO ELITE...
35 (A65053)
35 (A65053)
