5410 brakes dragging?
/ 5410 brakes dragging? #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
My neighbors 5410 had dragging brakes. I advised him to replace brake piston pull-off springs & piston o-rings which he did. After reassembly brakes still drag. Anyone have any ideas?
Thanks,Jim
/ 5410 brakes dragging? #2
When reassembling the pistons in the final drive housings, he needs to be sure the pistons went all the way in until they bottom out. That assures that the piston is reset properly after brakes are applied. If he is sure of that, then I might suspect brake pedal stop screws might be out of adjustment, which would keep the return oil after brakes are released from returning to reservoir.
My neighbor stated he had pistons pushed in completely. I suggested for him to check the stop screws but I'll check to see if he ever checked the screws.
Thanks for reply,Jim
/ 5410 brakes dragging? #4
I was reading my tech manual for the 5X10 and read this page. Maybe it will answer the problem.
  • brakedrag.pdf
JD5210
Thanks for posting that info. I'll forward it to my neighbor.
Jim
/ 5410 brakes dragging? #6
Takes special adapter, two service techs and if the pedal goes to the floor, leave it overnight, then two service techs the following day.. That gets one brake pedal adjusted. If the second one "goes to the floor", then they come back the third day to finish the job.
Hopefully that doesn't happen that way, but the cost just to adjust the brakes can get pretty steep.
