5400 Clutch Replacement
/ 5400 Clutch Replacement #1
wkpoor
Platinum Member
Amanda, OH
John Deere 5400, Farmall H, Farmall Cub, Allis Chalmers CA
Last year I had the tractor split due to a clutch that intermittently wouldn't fully release. It would drag just enough to lock up the shifter or sometimes I would need the brake to stop it. Upon inspection it was determined to be dried grease on the transmission spline, and the clutch looked fine. Tractor has 1500hrs. Put it back together only to discover that wasn't the problem.I put up with it all year till finally decided it was a real pain and besides I could be doing harm to the transmission synchronizers. So last month I had it split again and a clutch put in. FIXED!!! Finally. Old clutch shows very little wear. I have all the luck. Most people install clutches that start slipping and are wore out. I have replace one that won't give up and isn't wore hardly at all.OBTW the new clutch was 100.00 more than last year.
/ 5400 Clutch Replacement #2
That is exactly the luck I have!!
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2003 FORD F-750 SUPER DUTY(INOPERABLE) (A67714)
2003 FORD F-750...
BOX OF " NO TILL" DISCS (A65054)
BOX OF " NO TILL"...
2011 Chevrolet Impala Sedan (A66738)
2011 Chevrolet...
2004 NiftyLift TM50 HGE 50ft Towable Articulating Boom Lift (A66734)
2004 NiftyLift...
213121 (A64276)
213121 (A64276)
