54"MMM or 62"MMM
/ 54"MMM or 62"MMM #1
CFHartman
Keyser WV
John Deer 2210
54\"MMM or 62\"MMM
Can someone help me with this decision? I want to buy a new 2210 next spring with a FEL but I don't know which mower I want. The 54" or the 62". I now one a JD 214 I have had for 23 years with a 48" mower. Are there any pros of cons on eather one.
Thanks /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif <font color="green"> </font>
/ 54"MMM or 62"MMM #2
Re: 54\"MMM or 62\"MMM
My JD855 is 24 hp. Deck sizes for that era were 60" and 72". Although either would fit, my dealer talked me out of the bigger deck. No regrets. My lawn is not super thick, but the engine can begin to bog down in the thickest areas.
If the 2210 has less hp, I would probably go with the smaller of the two decks you're considering. This is not really a suggestion, just probably the way I would do it. On the other hand, I believe some TBNers with 855s use the larger deck. I'd be interested in their comments.
More to the point, there are probably 2210 users that have experience with both decks. I'm sure their input will be flowing soon.
Congrats on your future purchase! And welcome to TBN.
OkieG
/ 54"MMM or 62"MMM #3
I've got a 54" deck on my scott LM its works fine, But the new 4410 has a 72" RFM on its amazing how much faster it is . If you have a flat yard I'd go with the larger one...GOOD LUCK
/ 54"MMM or 62"MMM #4
If you don't have to many areas where the 62" MMM will not fit I would vote for the 62" deck. By sticking out further it can actually make trimming and/or cutting close to something easier without the tractor getting in they way. I have a 4110 and I am glad I went with the 60" vs. the 54" MMM.
Good luck, Have fun !!
DGB
/ 54"MMM or 62"MMM #5
I have a 2210 with the 62" MMM. I can mow right up next to things sometimes negating the need to come back and trim. The deck combined with the hydro tranny really make for a precision cut.
my $.02
wickman
/ 54"MMM or 62"MMM #6
I did not even consider the 54. When I bought mt JD335, I went with the smaller deck. I regretted it for a long time, so when time came for the 2210, the bigger the better. I have had no problems cutting grass that was 8" high at times.
/ 54"MMM or 62"MMM #7
hi
I have the 2210 with the 62 and mulching kit, it gives a very nice cut. I'm pretty imprssed with how nice my not so nice grass looks. I think the biggest reason for the 62 is it sticks out past the wheels enough to make it easier to trim close.
Power wise it handles it fine, sure if the grass is long and thick you may have to slow down a bit, but normal cutting no problem.
Phil
/ 54"MMM or 62"MMM #8
I have a 335 with the 54 and a 2210 with the 62. Even mowing at the same speed, you can cover a lot more ground with the 62. I'm finding that with sharp blades my ground speed can be quite a bit higher, too (this would be the case with either deck on the 2210 I believe). I have mowed some fairly high grass with the 2210 and the engine handles it fine.
The only reason I can see for getting the 54 would be a narrow gate or tree spacing.............
/ 54"MMM or 62"MMM #9
I know I am on the mid-chassis (4410) vs your small chasis (no offence).
I was between the 60 and the 72. Absolutely love the 72, makes it easier to get close to trees when mowing, also moves through the job very quickly.
/ 54"MMM or 62"MMM #10
I have a 2210 with the 62" MMM. For all of the reasons already mentioned, I wouldn't go any smaller.
Even though the web site shows that the 54" deck is an option for the 2210. I haven't heard of anyone who actually has one. Most come set up with the 62" deck when they're assembled, or they have no deck at all.
/ 54"MMM or 62"MMM #11
I have a 54 inch deck for my 2210..It trims very well around trees and fits between objects very well in my application..The 54inch deck makes the machine more versitile for me..I had a 60 inch deck on my Cub for 16years and do not miss it..It is all about where you wil be using it. 8 inches really is not that noticable in the larger areas. In my opinion.. There is a joke there in that last sentence, but I aint going there.. /forums/images/graemlins/grin.gif
/ 54"MMM or 62"MMM #12
I have the 54 too. I've got hills and trees and real tight mowing conditions, so the 54 is a good size for me. If I had flat wide open mowing, I would've gotten the 62. Anybody know what the weight difference is? I know the 54 is all I want to handle.
/ 54"MMM or 62"MMM #13
I'll say that IF fitting a 62" through some areas is a problem, then go with the 54", but if not, definitely go 62". I have never regretted the cutting width of my 60" over the optional 54". You will most certainly lap at least 3 to 6 inches on each cut on at least ONE SIDE of the deck. Depending on how you mow, that can double if you are "straddling" a row of uncut grass. Yes, it is only a few inches, but translate that into X number of rows, and before you know it, you've added X number of additional rows to make up for the lost "laps". A 62" deck is probably really only letting you cut about 50"-56"... let me clarify that YOU are only letting it cut 50" to 56". So, the 54" now looks like 42" to 48" deck. I never really though much of it until I made my lawn striping attachment 60" - the width of my deck. The stripes looked skinny. Because of the lap, the rows actually turn out closer to the 52" to 54" width. Yeah, lap widths may vary, but it's not the closed end of the deck that we can't get right up to the edge of the uncut grass, it's the discharge side... at least for me. I remember my grandfather's old mower had a "CUT LINE" embossed on the discharge side of the deck. That's what I've been threatening to do to my deck for years... mark the edge of the blade on top of the deck (discharge side only) so I always maximize my cut width. On a small lawn, it is a mute point. On larger lawns, or fields, a few extra rows X a few hundred feet per row can add up. In terms of the extra width maneuvering, I'll bet you'll never notice the difference. Like driving a big truck... you'll get used to it. Also, your neighbors will say, "Man, He's Got 62" of Pure Cutting Potential!" /forums/images/graemlins/grin.gif
/ 54"MMM or 62"MMM #14
Could you give pictures of your lawn striping attachment?
Roger
/ 54"MMM or 62"MMM #15
Sure. Here is what I posted on TBN recently.
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2012 FORD E-350 CUTAWAY SERVICE BODY TRUCK (A59914)
2012 FORD E-350...
2015 JET 42' ALUMINUM HOPPER BOTTOM TRL (A64277)
2015 JET 42'...
2006 Bentley Continental Passenger Car, VIN # SCBBR53W76C033311 (A65563)
2006 Bentley...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
1995 INTERNATIONAL 4900 S/A SPREADER TRUCK (A64277)
1995 INTERNATIONAL...
