5303 tranny locks up when cold
/ 5303 tranny locks up when cold #1
Tony S
Bronze Member
BRF WI
55 Super John Deere 5303
This has happened the last few years. My 2008 5303 won't shift into gear when its been cold out. If its been below freezing for a week or better when I take it out of park I can't move the lever over to put in gear, if I am able to move it I can't get into reverce untill it warms up for 1/2 hour or so. Once it goes into gear its good feel normal. Is there a possibilty of having water in there somewhere?
/ 5303 tranny locks up when cold #2
I'd suspect water..
Do you have a warm place to keep it for awhile, and drain/change the tranny oil? Or at least drain enough to see if there is water in it.
No its in a shed up on my land. I changed all the fluids 2 summers ago thinking that was the problem. Still has the same problem last winter and this. I think its water also but don't know where.
/ 5303 tranny locks up when cold #4
Should be able to get it hot enough by using it to do a tranny drain and fill.
I think that I found the problem. I found where its not uncommon for water to get in around the shift boot. I will take the bottom plate off and see if there is water in there.
I think I got it fixed. Took the plate that is under shifter off and found water and oil. Cleaned it up so hope that is the fix.
/ 5303 tranny locks up when cold #7
Hope that fixes the problem. I assume you did a complete tranny oil change to get rid of the water/oil mixture.
Curious, If this tractor is in a shed, how does water get around the shaft boot?
I bought it used, maybe it was in there from before I bought it. I think it did this for as long as I have owned tractor. When I changed oils before there was no water that you could see. I don,t think there is over 30 hrs on it after service. We will see if its. fixed. Cleaning this will be part on main. from now on.
