5205 Questions
/ 5205 Questions #1
boe
Howdy...
I'm NOT a very smart Tractor-Man, so wanted to ask a couple Trouble-Shoot
Questions of the experts...
1. Tractor has been sitting about a Month, went to do some Road Repair AND
Bush-hogging, noticed the following issue(s)
Started up right away, but Hydralics are Very Jerky--- Trying to Raise the Bucket OR 3-Point, They Move a bit, then Stop---Steering affected as well
Could this be Low Fluid Level OR a dirty filter??
2. (This is probably REAL dumb) I noticed the PTO Oil at thr rear was not visible in the Upper sight gauge... (Dumb Question Time) Is PTO Oil and Engine Oil the same???
Thanks...
Boe
/ 5205 Questions #2
The oil sight gauge you are seeing is for the hydraulic as well as transmission oil. If not visible it sounds like is low on oil, the engine oil is checked with its own dipstick and will be on the side of the engine with a yellow handle.
/ 5205 Questions #3
Welcome to TBN Boe:D
Like CTL said, the rear site glass is on the oil tank for the whole hydraulic system-so if it's low then that would explain your problems.
Do you have a manual? If not then here is a link to it: 5205
/ 5205 Questions
Thanks...
Getting some JD Hyd Oil today. Hopefully that will fix issues...
Boe
2015 BIG TEX T/A UTILITY TRAILER (A67714)
2015 BIG TEX T/A...
CAT 953C Cab (A68134)
Dixie Chopper (A64557)
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
ALLMAND  MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
