Oil & Fuel 5205 Fuel Filter
/ 5205 Fuel Filter #1
Lsquared
Eastern Kansas
Today I learned the hard way that there is a flat gasket at the top of the fuel filter on a 5205. That was a first for me! I changed the filter, but I could not get the engine to start. I bled the filter, the fuel return line and I even tried to bleed the injectors. No luck. I finally called the local dealer and a mechanic came out. He scratched his head for a while before finding the gasket and the leak. After replacing the gasket and filter locking ring, I only had to bleed the filter, prime the system and it started right off. Moral of the story, check to see if you have a gasket and have a spare on hand! :eek:
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2022 EZ-GO ELITE...
1997 Fontaine 48Ft Flatbed Trailer (A64194)
1997 Fontaine 48Ft...
John Deere 5055E (A64126)
John Deere 5055E...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
