5145 no power to main fuse box
   / 5145 no power to main fuse box #1
josephjohnson860
Mahindra 5145
Tractor won’t start it has no power to main fuse box. Battery is good I checked. Cluster will not come on. I checked fuses in box and there good but did not check relays. Is there a fuse that sends power to the main box???
   / 5145 no power to main fuse box #2
Welcome to TBN!
I do not know the tractor, but you may look at the top, main post of the starter for a loose connection or a fusible link that moght have melted.
Alternately, you can follow those wires off of that post to see if there may be a main fuse inline to the fuse box.
   / 5145 no power to main fuse box #3
Hi Joseph, my eMax has 3 fuses right near the battery. One is a 40amp which blew and caused the symptoms you have. I didn't realize the in-line fuse was there until they pointed it out.
   / 5145 no power to main fuse box #4
from the service manual, sorry for fuzzy pdf but that is the best i have
  • Pages from pdfserv5145.pdf
  • Pages from pdfserv5145 1.pdf
FYI for anyone with the same problem dealer found a fuse behind the battery box when fully pulled out. I couldn’t find it on and diagram I saw, but check or look for if having similar problems. Thx
Bell 1600 Gallon Nurse Trailer (A56438)
Bell 1600 Gallon...
JOHN DEERE 310SL BACKHOE (A60429)
JOHN DEERE 310SL...
2013 Freightliner M2 Box Truck (A59814)
2013 Freightliner...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56438)
LMC 2-Row Planter...
2012 Ford F-250 4x4 Pickup Truck (A60460)
2012 Ford F-250...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
