5145 no power to main fuse box
   / 5145 no power to main fuse box #1
josephjohnson860
Mahindra 5145
Tractor won’t start it has no power to main fuse box. Battery is good I checked. Cluster will not come on. I checked fuses in box and there good but did not check relays. Is there a fuse that sends power to the main box???
   / 5145 no power to main fuse box #2
Welcome to TBN!
I do not know the tractor, but you may look at the top, main post of the starter for a loose connection or a fusible link that moght have melted.
Alternately, you can follow those wires off of that post to see if there may be a main fuse inline to the fuse box.
   / 5145 no power to main fuse box #3
Hi Joseph, my eMax has 3 fuses right near the battery. One is a 40amp which blew and caused the symptoms you have. I didn't realize the in-line fuse was there until they pointed it out.
   / 5145 no power to main fuse box #4
from the service manual, sorry for fuzzy pdf but that is the best i have
  • Pages from pdfserv5145.pdf
  • Pages from pdfserv5145 1.pdf
FYI for anyone with the same problem dealer found a fuse behind the battery box when fully pulled out. I couldn’t find it on and diagram I saw, but check or look for if having similar problems. Thx
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A55218)
2019 Energreen EVO...
2014 CATERPILLAR 120M2 MOTORGRADER (A52705)
2014 CATERPILLAR...
UNUSED 3.5X2X2M GREEHOUSE (A54757)
UNUSED 3.5X2X2M...
2014 Ford Explorer SUV (A55758)
2014 Ford Explorer...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2015 DODGE RAM 4500 HD SERVICE TRCK (A54756)
2015 DODGE RAM...
