5145 no power to main fuse box
   / 5145 no power to main fuse box #1
josephjohnson860
Mahindra 5145
Tractor won’t start it has no power to main fuse box. Battery is good I checked. Cluster will not come on. I checked fuses in box and there good but did not check relays. Is there a fuse that sends power to the main box???
   / 5145 no power to main fuse box #2
Welcome to TBN!
I do not know the tractor, but you may look at the top, main post of the starter for a loose connection or a fusible link that moght have melted.
Alternately, you can follow those wires off of that post to see if there may be a main fuse inline to the fuse box.
   / 5145 no power to main fuse box #3
Hi Joseph, my eMax has 3 fuses right near the battery. One is a 40amp which blew and caused the symptoms you have. I didn't realize the in-line fuse was there until they pointed it out.
   / 5145 no power to main fuse box #4
from the service manual, sorry for fuzzy pdf but that is the best i have
  • Pages from pdfserv5145.pdf
  • Pages from pdfserv5145 1.pdf
FYI for anyone with the same problem dealer found a fuse behind the battery box when fully pulled out. I couldn’t find it on and diagram I saw, but check or look for if having similar problems. Thx
Case IH MX270 Tractor (A59814)
Case IH MX270...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
Landoll 876C Soil Finisher (A59814)
Landoll 876C Soil...
2007 Western Star 4900 Semi (A59814)
2007 Western Star...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
