5103 won't turn over.
/ 5103 won't turn over. #1
Jns66
Rockport, IN
John Deere 5103
I left the ignition switch on. After charging the battery, the tractor won't turn over. When I jump across the starter relay, it turns over. I changed out the starter relay, still does the same thing. Battery, alternator, and starter/solenoid are good. Any ideas?
/ 5103 won't turn over. #2
Check neutral start switch for continuity? Do you have pto OFF?
/ 5103 won't turn over. #3
I have attached the start system wiring diagram for the 5103. As already suggested I would check the PTO and neutral start switch.
Must likely not the problem, but it would not hurt to check the fuses.
  • 5103starting_system.pdf
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
HAMM 2210 SSD PADFOOT COMPACTOR (A67714)
HAMM 2210 SSD...
PORTA POTTY (A67714)
2009 POLAR TANK . (A67714)
2009 POLAR TANK ...
2013 Ford F-150 Crew Cab Pickup Truck (A66736)
2013 Ford F-150...
