Loader 5103 512 Loader mounting frames
/ 5103 512 Loader mounting frames #1
Boomer53
John Deere 5103
Considering adding a front end loader (JD 512)to my basic 5103. Per JD sales they don't make/sale the loader mounting frame. W/o the frame can not proceed. Any thoughts or suggestions on where to find the frame parts other than upgrade to a newer tractor with a loader already installed. Have searched the net with no luck.
Welcome to TBN
Might find what you are looking for at JD parts
Looks to be available.
Started with my locale JD dealer. He was the one who stated: they not available anymore, have not been made due to the series of tractor out of production. Unless they come off an existing 5103 for parts, very hard to come by. One option I found was to order from India, apparently they are readily available over there. Thanks
/ 5103 512 Loader mounting frames #4
Put up some pics of what you have available on the model 512 loader.
Apparently no frame parts at all?
Getting the frame fabricated from the schematics linked in JD parts could be a consideration, but at what expense?
/ 5103 512 Loader mounting frames #5
It's not really a great tractor for loader work. Gears aren't synched very well and 2-wheel drive, etc. A hydrostat or something with power-reverser and 4-wheel drive and R4 tires might be a better option.
Just my opinion.
You don't necessarily have to "upgrade to a newer tractor". Just find something you like that already has a loader on it.
Again, just my 2 cents.
/ 5103 512 Loader mounting frames #6
It looks to me as if the mounting frame parts are all available though parts department. The are Quite expensive because each part is ordered individually instead of the complete bundle that was originally available through sales dept. My guess is around $5000 for left and right frames with adapter plates and hardware.
/ 5103 512 Loader mounting frames #7
Or go with an aftermarket loader. I have a Koyker 185 on one of my 5403, and it has been a good loader. Their website shows the same loader for the 5103, since it has the same frame size. It has been in use for over 15 years without problems. My other two loaders are JD.
/ 5103 512 Loader mounting frames #8
I'd think a 512 would be "whole goods" only as it's not a QA loader. I understood there are only one set of mounting frames / loader towers and they only came with the loader.
553 was the QA loader for those tractors, not sure what the newer models are, but what ever fits a 5045D might fit.
The 9x3 gear box isn't great for loader work, only EXTRA SLOW, TOO FAST and WARP SPEED for reverse gears.
Thanks for the reply. These are the mounting frames needed for the 5103. Attachment ID code BW15858 left and right side. My locale JD supplier has the 512 loader with all the accessories just not the mounting frames.
Just my opinion.
Thanks for your reply. Just need the loader for small jobs nothing major, hay bales, trash, minor dirt work etc. Only have the one tractor. Almost easier to rent a loader at this rate.
Thanks for your reply. Based on talking with the JD sales rep at my locale store on the inquiry for a 512 loader for the 5103, based on his past experience the mounting frame/plates were no longer made due to the 5103 series no longer made. I guess I should call parts and inquiry with them. Per chance did you check or just look up parts cost on line. Thanks
Thanks for your reply. Have explored Westendorf and it appears they can support my requirement for a loader. Checking on the mounting brackets if they can provide or not. I am standing by for their response.
Thanks for your reply. Per the JD rep they have 512 loaders with all the accessories just not the mounting frame/towers. Without those can not move forward. Have checked about other loaders but the JD 512 is the only loader that works with the 2 wheel drive 5103. Am exploring non JD loaders if doable. Thanks
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
110 GAL WATER TANK (A68842)
110 GAL WATER TANK...
PRESSURE WASHER (CONDITION UNKNOWN) (A68842)
PRESSURE WASHER...
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A66734)
2025 Kivel Quick...
LINCOLN ELECTRIC POWER MIC WELDER SETUP (A67714)
LINCOLN ELECTRIC...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
