5101e 4X4 Engadged Indication
   / 5101e 4X4 Engadged Indication #1
stickfarm
Georgia
John Deere 5101e ltd
There is no indication my 5101 is in 4 wheel drive. I know the 4 wheel drive is working, just wondering if there should be a light or something? Thanks.
   / 5101e 4X4 Engadged Indication #2
No indicator in the dash?
   / 5101e 4X4 Engadged Indication #3
The 5101e has a manual shift (lever) to engage the 4-wheel drive, correct? Since it's not an electric selenoid engagement you likely don't have an instrument panel indicator (light).
Just the lever position.
AKfish
Correct, it is a manual engagement. I see the 4wd icon light come on when I start the tractor, but failed to come on when 4wd engaged. Thanks for info.
Whats your opinion for a harrow for this tractor? No real cutting; mostly scratching for overseeding hay fields and smoothing rough spots. I'm thinking JD210. Just not sure how wide I can get away with.
Thanks for your time.
   / 5101e 4X4 Engadged Indication #5
Well, you've got plenty of power... and if you're only thinking of light ground work - you'll be able to go with a wider disc.
One other consideration is rear tire slippage. Are your rear's filled or do you have wheel wts.? You can work a wider disc with some added "@ss weight"!
Don't know how wide the JD210 is. I used to work a light-duty 12' tandem disc with a 2WD JD3020 and no problems. Had fluid rears, though.
Worked a 14' medium duty tandem disc on a JD4020 and fluid rears, too. Crop clean-up in the fall and knockin' down the high spots!
AKfish
   / 5101e 4X4 Engadged Indication #6
My 2010 5083e was the same way and annoying. The indicator is there, the light behind it is there, but it isn't activated. My new MY2012 5083e has a working pto and 4x4 indicator.
I can live with it; never had a light indicator before. Thanks for the info and your time.
   / 5101e 4X4 Engadged Indication #8
I asked the dealer about that on mine, and he told me it didn't have it. That is the same dash they use for many of those tractors, and I guess some have it and some don't. My little 3520 had it.
You could put a switch on it and wire it to the dash and probably get it working. It is silly that they cut corners like that.
   / 5101e 4X4 Engadged Indication #9
I was wondering the same thing on my 5083E... That is dumb that they did that...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2016 Ford F-150 Crew Cab Pickup Truck (A49461)
2016 Ford F-150...
1996 NEW HOLLAND 3930 WITH LOADER (A51243)
1996 NEW HOLLAND...
2018 FORD F-150 (A50854)
2018 FORD F-150...
2019 KENWORTH T680 SLEEPER (A51222)
2019 KENWORTH T680...
