5101e 4X4 Engadged Indication
/ 5101e 4X4 Engadged Indication #1
stickfarm
Georgia
John Deere 5101e ltd
There is no indication my 5101 is in 4 wheel drive. I know the 4 wheel drive is working, just wondering if there should be a light or something? Thanks.
/ 5101e 4X4 Engadged Indication #2
No indicator in the dash?
/ 5101e 4X4 Engadged Indication #3
The 5101e has a manual shift (lever) to engage the 4-wheel drive, correct? Since it's not an electric selenoid engagement you likely don't have an instrument panel indicator (light).
Just the lever position.
AKfish
Correct, it is a manual engagement. I see the 4wd icon light come on when I start the tractor, but failed to come on when 4wd engaged. Thanks for info.
Whats your opinion for a harrow for this tractor? No real cutting; mostly scratching for overseeding hay fields and smoothing rough spots. I'm thinking JD210. Just not sure how wide I can get away with.
Thanks for your time.
/ 5101e 4X4 Engadged Indication #5
Well, you've got plenty of power... and if you're only thinking of light ground work - you'll be able to go with a wider disc.
One other consideration is rear tire slippage. Are your rear's filled or do you have wheel wts.? You can work a wider disc with some added "@ss weight"!
Don't know how wide the JD210 is. I used to work a light-duty 12' tandem disc with a 2WD JD3020 and no problems. Had fluid rears, though.
Worked a 14' medium duty tandem disc on a JD4020 and fluid rears, too. Crop clean-up in the fall and knockin' down the high spots!
AKfish
/ 5101e 4X4 Engadged Indication #6
My 2010 5083e was the same way and annoying. The indicator is there, the light behind it is there, but it isn't activated. My new MY2012 5083e has a working pto and 4x4 indicator.
I can live with it; never had a light indicator before. Thanks for the info and your time.
/ 5101e 4X4 Engadged Indication #8
I asked the dealer about that on mine, and he told me it didn't have it. That is the same dash they use for many of those tractors, and I guess some have it and some don't. My little 3520 had it.
You could put a switch on it and wire it to the dash and probably get it working. It is silly that they cut corners like that.
/ 5101e 4X4 Engadged Indication #9
I was wondering the same thing on my 5083E... That is dumb that they did that...
